Question about The Watches
How to remove watch band on skme1 1155 watch?
Nice watch, need to change the battery
Go on Ebay and buy yourself a 'spring-bar tool'. It has a tiny forked tip (2-prongs) that fits around the end of the 'pin' that holds the spring-bar to the watch--push down and lever it out, and your watchband will come off. They're only a coupla bucks.
Posted on Feb 12, 2019
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
  • 3 Answers
SOURCE: watch band
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
1 push pin like you use on bulletin boards with a plastic head
1 small hammer like a tack hammer
1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Dec 31, 2007
SOURCE: How to remove links from Fossil metal band?
I've had a Fossil before, but forgot how easy it is. Thanks for the refresher.
Posted on Jan 14, 2008
VOTIT
  • 2071 Answers
SOURCE: Beverly HIlls Polo watch needs band adjustment
All you prepare a piece of jewelry screw.There will be very tiny screw in the side of the band you better screw it carefully and when the screw is out detach it,and size it that's you like size comes out.That all if want to resize desame what did in the other side. Always do it slowly so there no scratch or visual impaired damaged.
Posted on Jun 17, 2008
SOURCE: Remove links from metal watch band
This was on a Seiko Dive watch SKX007. This has the metal links joined with pins, which, you will find, are split/spring down their length.
I used a neoprene mouse mat as a work surface, which was ideal as it allows the pin to move out, whilst supporting the links and stopping any slippage. I also rigged a table lamp close by.
There is an arrow which shows in which direction the pin needs to be pushed to remove it. Look carefully and you see that one end of the pin is slotted a little, the other is plain. Push the plain end in the direction of the arrow firmly... it's a leap of faith.
As a tool, I used a cocktail stick to start with. It required firm pressure and then it suddenly gives. I was able to draw the pin out by hand, but used pin nose pliars in one instance, as some pins offer more resistance than others. In most cases the cocktail stick worked (I got through a few). I then graduated to a thumb tack which was more reliable, but metal to metal, so a bit more worrying.
Sliding the pin back was simple, though take care to get the smaller links the right way up when it is re-threaded. I pushed it home the last few millimeters with the flat side of the pliers, giving a final push with the cocktail stick. Good luck. Simplysimon.
Posted on Oct 01, 2008
SOURCE: fossil watch band adjustment
throw the ******* thing away
Posted on Dec 25, 2008
How to change watch band on invicta angel stainless steel band
Turn the watch over and you will see that the band is attached to the watch with spring loaded pins. There is room to put a spring removal tool in the available slot and depress the spring which will allow you to twist the band away from the watch. Be careful to not loose the spring loaded pin as you may need it to install another band. Almost every watch uses this method of band removal. Those that don't usually have a long screw that is accessible from the side of the watch.
Feb 19, 2013 | Invicta Reserve Subaqua Venom Swiss Quartz...
I have an nike oregon series watch and need to replace the band. i have the replacement band but do not know how to change it.
It looks like the outer steel ring on the back (with the 6 indentations) must be removed before the strap can be taken off. You will need a watch case opener for this - these go for very little money on auction sites. Possibly, the battery hatch needs to come off first.
Jul 17, 2011 | Nike Oregon Series Digital Super Watch...
Need to change battery in EH23sa
The battery is actually accessed from the front of the watch.
You should have a "Case Knife" to remove the front bezel.
Remove the band first.
Set the watch in its side. Set the case knife at the groove where the watch band holder meets the front bezel, and give the back of the knife a sharp rap with a small hammer. The front bezel should pop off.
Some watches have a small circular plastic piece that will also come out. Gently remove the movement from the front. The battery (CR 2025) can then be removed from the back of the movement using a small, thin blade. Install the new battery. The inside back of the case should have restart instructions. (Push A -left button once. then push and hold A until hands move to 12:00. Push B once to start reception.
The back of the watch is plastic. Don't try to remove it.
Gently re-assemble movemengt. A watch case press tool is best for finishing assembly. I would suggest taking the watch to a jeweler if you are uncomfortable taking this watch apart. Good luck
Mar 21, 2011 | Watches
Got this watch for xmas, nice. the band is too big. how do i adjust the metal band?
u can have ur watch to the watch shop they may make it short fitting on ur hand
Jan 04, 2011 | Invicta 100 Meter Sport Diver Quartz...
I have a Triax Speed 50 Nike watch and the local jewelry store would not change the battery because the possibilty of damaging the wrist band that needs to be removed. Any instructions on how I can change...
You can't change it yourself without doing damage. You will need to send into Nike or more accurately an authorized nike watch repair center that is close to you hopefully.
Nike customer service or a google search for authorized nike watch repair in XXX-city will get one close to you.
Dec 27, 2010 | Nike Timing Triax V10 Watch
How iI open a casio 705 woman watch?
Thank you for contacting FixYa.
You will need:
  • A jeweler's screwdriver- Either flat head or Philips, depending on the model of watch.
    A cup or small box-This is to hold any screws.
  • How to change a Casio watch battery:
    1. Spread a cloth over your work area The cloth will help you avoid damaging the finish on your watch.
    2. If necessary, remove the watch band Removing the band gives you easier access to the back plate.
    3. Remove the back plate For some models this means using a screwdriver to gently pry it open, and others require removing screws. Keep small screws in a container to avoid losing them!
    4. Take note of the rubber seal Sometimes they need to be reinstalled in the same orientation. You might even want to use a marker to make a small "match mark" before removing it.
    5. Locate the battery It looks like a small metal button.
    6. Remove the battery You might need to loosen (not remove) a small screw and slide a latch out of the way. For other models, it's as simple as popping open a strap that is stretched across the cell.
    7. Install the new battery Make sure it's in the same orientation as the old one. They usually go in with the positive (+) side down.
    8. Perform a reset Do this by touching one tip of the tweezers to the AC contact, inside the watch, and the other tip to the back of the watch battery.
    9. Make sure the watch is working properly Carefully lift the watch to do this. Don't turn it over or the watch movement might fall out.
    10. Reassemble and seal the watch Perform steps one through four in reverse order to reassemble your watch.
    Best regards. Jewel
    Sep 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    The rubber band broke on my seiko dive watch--unable to get the pins out without breaking them--any suggestions on removing the pins
    mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
    Jul 21, 2010 | Seiko SGF204 Wrist Watch
    Change casio g shock resin watch band
    It can be done and not too difficult i think but look out that the leather band ain't too wide for the band orginal place,
    make sure you keep all original parts in case of toruble
    Post a photo if you can after the change will be nice to see the change
    Tom
    Nov 10, 2008 | Casio G-Shock GW500A-1V Wrist Watch
    Replacement band for nike watch wa0018 oregon alt
    I wear the smaller, womens' version of the Nike Oregon. Nice watch. I was attracted to it by the replaceable battery feature, but found out the strap goes long before the battery and the joy of ownership goes out the window with the price of Nike wrist-band replacement. I held onto my broken banded watch for awhile, and came up with a solution. First, don't try removing the screws that secure the watch-band pins. Not sure how they work, but I tried several times without luck. Even had a jeweler look at it without success.
    I went to Kohl's and purchased a black velcro Timex replacement band for $8. Again this is the for the smaller version of the Oregon. The width of the timex band in 3/4". It includes a elastic band to secure the watch. This elastic band runs under the back of the watch and over the two pins. It is secured to a faux leather tab (with emblems), which is in turn attached to the velco band. Using a razor knife, I detached the faux leather pad from the velcro band and ran it under the watch pins, then reattached it with a touch of Gorilla glue. Be careful to wipe off any excess as Gorilla glue expands as it dries. Finally I blacked out the Timex advertising with a black felt permanent marker.
    No reason to think this wouldn't work on the larger, mens' version of the same watch.
    Apr 18, 2008 | Nike Oregon Series WA0019-001 Wrist Watch
    Removing the back to change battery
    The plastic wrist band doesn't have to be cut away. You need to dislodge the spring-loaded end of the pin from the hole in the plastic with the blade of a sharp thin knife.
    The you proceed to lift one of the 4 snaps to open the cover. The battery is under a white translucent inside cover.
    The original battery was Sony SR621SW.
    Pay attention to the rubber seal ring when putting the watch back together.
    Jan 13, 2008 | Casio MQ24-7B2 Wrist Watch
    Watches Logo
    Top The Watches Experts
    vince
    D. E. Hev
     Larry
    Larry
    Are you a The Watch Expert? Answer questions, earn points and help others
