SOURCE: why wont my Jet pump shut off?
Is the little pipe that connects to the pressure switch clear?
I suggest you remove it and blow through it to make sure it is clear. If the pressure is getting to the switch, it has to shut off ... your switch should be set around 30/50 (on at 30 - off at 50)
SOURCE: I have a 1/2 horse wayne shallow well pump. At
check air in your water tank should be less than you're cut in pressure..
