Question about Frigidaire Dryers
Frigidaire affinity electric dryer r11 codes - Frigidaire Dryers
SOURCE:
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 1531 Answers
SOURCE: have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
Posted on Sep 17, 2009
Daniel S
  • 4323 Answers
SOURCE: frigidaire affinity electric dryer, error
Hi
E68 error code indicates current leakage to ground on heater or fuse opened. Check the resistance of the heating element; it should be around 14 ohms. Also check the resistance between the ground and both heater terminals, it should be open when heater terminal are disconnected. If the readings are incorrect then the heating element should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 24, 2011
  • 9 Answers
SOURCE: My Frigidaire Affinity dryer won't tumble; it just hums
Thats not even a question Stupit!!!! A good hummer is good for you ********!!!!
Posted on Aug 04, 2012
alaskabrat11
  • 353 Answers
SOURCE: How/where can I find an error code on my Frigidaire Affinity electric dryer?
online owners manual,what is it doing?
Posted on Jan 02, 2015
What do error codes FDL and R11 indicate?
Hello Lidia, thank you for your inquiry!
Based off the information you have provided your Frigidaire dryer is not heating and displaying error codes "FDL" and "RL". I am showing that the codes you have provided are not valid error codes. I would recommend performing a reset on your dryer and you can do that by disconnecting power from it for at least ten minutes. I see that you have already replaced the igniter; however, if you continue to have issues with the error codes I would suggest having a professional technician out. This will help you avoid any further unnecessary part purchases. Hopefully this information is helpful to some degree. -Matt
Feb 15, 2016 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Error E52 on frigidaire affinity
Hello friend, thank you for your post!
Based off the information you have provided, I understand that your Frigidaire dryer is displaying an "E52" code and the dryer will not start. Typically an "E52" code stands for motor fault, I would attempt to perform a reset on your appliance by disconnecting power for roughly ten minutes. After the reset if you are still receiving the error code I would recommend having a professional come out to diagnose and repair the appliance. Best of luck. -Matt
Aug 06, 2014 | Frigidaire Affinity Series FASE7073LA...
Clear codes for affinity dryer
Hi Friend, this is Z. I am happy to assist you!
I see that you have a Frigidaire Affinity dryer and I'm presuming you are seeking information on how to clear error codes on your dryer. May I please have your model number? The serial tag, which lists your model number, is typically located on the upper front, as you open the door. With this information I can help pinpoint the exact problem. In the meantime, you can reset your dryer by either unplugging your dryer or flipping off the breaker for roughly ten minutes. This often clears most false error codes. Hope this helps!
May 21, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidair affinity dryer error code Ad
AD is not actually an error code, but is typically considered an Air Dry setting or feature on the unit.
Aug 06, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
I have a Frigidaire Affinity Clothes dryer manufactured in 05/07 that is displaying a code E68 after in runs for just a few minutes. Any idea what could be causing this?
The error code E68 means a key or button is stuck. Check the buttons by pressing them one at a time to find the stuck one or enter the service diagnostic mode then the key function test. Click on the link below for the detailed instructions.
Troubleshooting Error Code E68 on Frigidaire Affinity and Gallery Dryers
Mar 06, 2011 | Frigidaire Electric Dryer
Frigidaire Affinity Electric dryer E68 error. dries clothes fine, then error light comes on later- after dryer has been off. Will not start unless unplugged for period of time.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Sep 15, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Have a frigidaire affinity electric dryer that doesn,t heat
Sep 06, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Open Questions:
Frigidaire faqe7011lw0 dryer having issues, not heating up and shuts off after 10 minutes My dryer model number is faqe7011lw0. It seems to start up, and then after about 10 minutes, consistently, it shuts off and has a bunch of blinking lights on the right side of the control panel. It started off with an error code of E4A which states "The drying time has exceeded program time for that cycle". I got that code to go away and then i got another code of "E4B" which states "Temperature reading of control thermistor has not changed in a certain amount of time". The second error code makes more sense because I notice in the 10 minutes that it runs, there seems to be no heat, so i feel something is causing the dryer to not heat up. The troubleshooting for this states to test a relay on the control panel, but I wanted to see if anyone else had this issue before. The weird thing about this is, if I run the dryer empty, the cycle completes the whole way through, but with wet clothes, it shuts off exactly at 10 minutes, no matter what cycle i set it to. I thought maybe this was a sign I had too large of a load in, so I took out about half the clothes, and ran it then. I still got the same issue. So I am kind of confused why when I run it empty, I get the full cycle with no error code, but with anything in the dryer at all, it stops after 10 minutes and gives me an error code. FYI, I have check the exhaust too to make sure it isn't clogged with lint, and it is wide open.
Mar 18, 2019 | Frigidaire Dryers
Dryers Logo
149 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
