Sewing Machines Logo
Kathy Benson Posted on Jan 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Settings for making buttonhole on Viking 64 40
pawnpower
Level 3:
Master:
  • Master 851 Answers
  • Posted on Jan 28, 2019
 pawnpower
Master
Level 3:
Master:
Answers
851
Questions
Helped
247176
Points
2332
Should be in the instructions booklet that comes with the machine or can be easily downloaded via the internet.
2 Related Answers
radcal
  • 196 Answers
  • Posted on Oct 02, 2008
SOURCE: Buttonholes
Put on the C foot. Select the buttonhole stitch. The machine will start sewing in the bottom left corner of the the buttonhole. Sew the length that you need, press and release the reverse button and sew the right side of the buttonhole. When you get back to the bottom, press and release the reverse button again and the buttonhole will be finished and the thread will tie off and the machine will stop. If the buttonhole is what you want, press and release the Stop button and the machine will repeat this buttonhole as many times as you need until the machine is turned off or the Stop is pressed again. When repeating, you need not press the reverse. Just press down on the foot control and continue until the machine stops by itself.
If you don't like the first one, just sew another one using the reverse button to set the ends.
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Aug 02, 2012
SOURCE: Viking 6360 buttonhole procedure
you start with the broad zig zag stitch bar across the top
then you go down the left side using a smaller zig zag stitch
then you make the the broad zig zag stitch at the bottom
then you make the smaller zig zag stitch on the right side
all the way to the top broad zig zag stitch & your done
the right side zig zag does not go beyond the top broad zig zag
stitch
Husqvarnaviking Jade 20 buttonhole Lever
If the buttonhole lever on your Husqvarna Viking Jade 20 sewing machine is not lowering enough to reach the buttonhole foot, it may be misaligned or not properly adjusted. Here are a few steps you can try to troubleshoot the issue:
  1. Check the Buttonhole Foot: Ensure that the buttonhole foot is properly installed and in the correct position. If the foot is not positioned correctly, it may interfere with the buttonhole lever.
  2. Check the Buttonhole Lever: Inspect the buttonhole lever for any damage or debris that may be causing it to get stuck or misaligned. Clean the lever and surrounding area with a soft, dry cloth.
  3. Adjust the Buttonhole Lever: You may need to adjust the position of the buttonhole lever to ensure that it aligns with the buttonhole foot. Refer to your sewing machine's manual for instructions on how to adjust the buttonhole lever.
  4. Contact a Professional: If you are still experiencing issues with the buttonhole lever, it may be best to contact a professional sewing machine repair technician who can diagnose and fix the issue.
It's possible that other users may have experienced a similar issue with the buttonhole lever on the Husqvarna Viking Jade 20 sewing machine. You may want to search online forums or communities dedicated to sewing and sewing machine repairs to see if there are any helpful tips or solutions.
Do you know Viking 5430 has buttonhole?
Best bet is to check your owner's manual. If it has a buttonhole function, there will be instructions on how to use it. If it doesn't you can always make them like we used to on the older machines:
Making Buttonholes Without Special Feet
How do i make buttonhole on viking freesia 425
Hello
See pagew 24 and 25 in the User's Manual. If you need to download a manual, here is the link
https://www.manualslib.com/manual/592717/Viking-Freesia-415.html
Happy buttonholing
Sewingirl/
stitch
I cant find my manual and have forgotten how to make butonholes with my viking interlude 435
If you look at the knobs on the machine they should have picture of buttonhole on them, you will have to turn them as you make a button hole.
How do i make button holes
Making buttonholes are very easy with the D-1. Do you have a manual? you need to put in the buttonhole foot and measure what size button you need to make the hole for, go to 'button hloes' on the menu of the machine and it will be self-explainatory.
I need to learn how to make a buttonhole on my Husqvarna 210 electronic sewing machine.My manual is gone.
You may be able to still get that manual, check with your dealer. If not you can call Viking at: 1-800-474-6437 if it's out of print for a photo copy of the original owners manual.
To make a buttonhole do the following:
1. Turn the selector dial to the top position, That is the first step of the buttonhole.
2. Turn the stitch length dial (the bottom dial) to the picture of the buttonhole, it's between the 0 and the 1 on the dial.
3 Put on the "C" foot and put the tension dial, (the small dial just above and to the right of the needle) on 4.
4. On a test fabric, sew about an inch or so and stop. Turn the selector dial down one click and sew the bar tack of the buttonhole. Just do a few passes, don't build up alot of stitches here.
5. Turn the dial down another click to the 3rd step, the right side of the buttonhole and sew until you reach the place where you started the left column of the buttonhole and stop.
6. Turn the dial UPWARD one click to the bar tack position again and do another bar tack like you did at the top of the buttonhole. Don't build up alot of stitches here, about three passes does the trick.
7 Remove the fabric from the machine and when you cut the threads, leave a tail about 2 inches or so of the thread. From the back side of the buttonhole, pull gently on the thread and a loop from the front thread will appear on the backside. Pull the front thread to the rear and tie off the threads and then cut them close to the knot you tied and the buttonhole will not come apart.
7helpful
Buttonholes
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
