SOURCE: Instruction Manual needed for Vivitar model 45 light meter
Here is a link to an on-line copy of the manual you need.
http://www.butkus.org/chinon/flashes_meters/vivitar_45_lightmeter/vivitar_45_lightmeter.htm
Hope this helps.
Jeff
SOURCE: HAVE INFINITY TELESCOPE, MODEL 60EQ-D, NO MANUAL,
Meade has a web site with their manuals:
Try these two links. Your small refractor assembles in a similar fashion.
http://www.meade.com/manuals/TelescopeManuals/Refractors/NewMeade60_EQ-D%208-03.pdf
http://www.meade.com/manuals/TelescopeManuals/Refractors/New%20Meade%2060%20EQ-A.pdf
Here is the direct link, look under the REFRACTOR heading:
http://www.meade.com/manuals/index.html
SOURCE: I have lost my manual
You can find the manual in this list: http://www.emersonradio.com/owners/MWO%20manual/ . It is a PDF
To change the power, press Power repeatedly. (It will change by one digit at each press - watch until you see 5 in the display.)
I hope this helps.
I suggest that you look for a similar White manual. Sometimes you can also run across these types of old manuals on Ebay or Etsy.
Good luck.
CD V-71, or CD V-715?https://www.radiomuseum.org/r/victoreen2...
