R
Robert weiss Posted on Jan 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change the ink cartridge
Sharp modelEL-1197P111
pawnpower
Level 3:
Master:
  • Master 851 Answers
  • Posted on Jan 28, 2019
 pawnpower
Master
Level 3:
Master:
Answers
851
Questions
Helped
247128
Points
2332
Instructions available on the internet - for your machine.
How do i change the ink cartridge
No ink cartridge - the ink is on the ribbon. Replace the ribbon if out of ink.
1helpful
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
1helpful
Refilled cartridge problem
There's some kind of a chip chip in the catridge that notifies the printer that the same cartridge has been refilled. to get around this check keep atleast 2 or 3 empty cartridges, refill and cycle them. That should do the trick!
SHARP 5320 INK CARTRIDGE
Depends where you are in the world, it would seem that if you are in Austailia or New Zealand it takes an AR202lt, anywhere else it takes an AR016lt, hope this helps
Ink cartridge
open right side door first then open front door
HELLO! I HAVE A SHARP FAX MACHINE (UXA1000- INK CARTRIDGE UX-C70B)AND I WANT TO KNOW IF I CAN GET THIS CARTRIDGE REFILLED AT WALGREN'S STORES LIKE MOST CARTRIDGES.
You should be able to, but the problem is this:
they only refill it, if there is a problem with the cartridge it doesn't help.
there is more to just putting ink in a cartridge.
1- you must clean the inside removing dried ink
2-you must clean the nozzles tomake sure the ink can flow
3-replace any pads inside
4-refill ink
I have heard complaints about Walgreens so take your chances, a better solution may be a company called Rapid refill ink ( they do all the above to their ink crtgs)
Sharp ux b700 will not print
it sounds like either you didn't peel off the plastic cover the ink cartridge or it is a defective cartridge.
Thank You,
Mikey
2answers
Check Cartridge Error - Sharp UX-B700 Plain Paper Inkjet Fax
I replaced my new $40 cartridge with another new cartridge and it worked.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
