SOURCE: Omnitech Wireless Weather Station model
Push and hold down the channel button, wait for beep, then on the sensor, push and hold the tx button, wait for beep.
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
SOURCE: outside temperature reading -40 and outside temperature sensor has been replaced
had the same problem, it needs time to calibrate, you have to drive it over 19 miles per hour for at least 10 minutes or so and it should reset itself. I would just take it on a drive if you haven't done so yet.
In some of these weather stations, you have to install the batteries in the transmitter first and then the weather station within a certain time limit. Also, the weather station must be within a specified distance from the transmitter when replacing the batteries.
If you look on the weather station, there should be a make and model number. If you have that, you can visit the website (if there is one) and download an instruction booklet for your model.
Press reset on both units
