Sewing Machines Logo
Terry Fletcher Posted on Jan 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to delete designs in the machines memory - Sewing Machines
pawnpower
Level 3:
Master:
  • Master 851 Answers
  • Posted on Jan 28, 2019
 pawnpower
Master
Level 3:
Master:
Answers
851
Questions
Helped
246985
Points
2332
Interesting question. the right answer could depend on what make and model you have, but, since you didn't tell us, we can only presume you don't know.
My Machine have an error message coming from the screen "BROKEN DESIGN DATA WILL BE DELETED FOR SYSTEM RESTORATION" Whats is the solution for this error?
I will need more information on make and model of embroidery machine this is.... a system reset need to flush out the memory and delete improperly saved or partially loaded embroidery designs.
Cheers,
Embroidery Services
San Diego, CA
1helpful
I have a USB flash drive with one pattern on it that I use often. Tonight, my machine won't read the pattern. I click on it, it says "wait while retreiving pattern", but nothing happens.
Hey Diane, THis is a guess but try deleteing some designs off of the machine's memory. I have a feeling it's small memory is full and can't accept or read any more designs until some room is made.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Janome 350e embroidery machine will not open files from usb
Machine memory is FULL. delete a few designs from the machine, and then you should be able to load a new design from the USB Drive.
Janome help
Your machine memory is full, delete a design or two from the machine's memory and you should be good to go with the new design.
Error with Daho BECS 2X8 embroidery machine
Sounds like a computer problem, like the the mother board. I would try contacting the manufacturer or distributor and ask to speak with a technician. It may be as simple as a bad memory stick. I will add my link
I would like to delete 2 files from the embroidery memory in the 180 module, not the card. I open the file, go to Layout 1, select DEL and nothing happens. This is as per the directions in the manual. What...
If you have the machine connected to the computer you can delete the embroidery from your machine, Artlink software is for this machine to write designs or read designs from your machine.
1helpful
2answers
Can not send designs from pc to mc 10000 .
Hi all have just solved the problem with a kind lady from Janome, the problem was my internal memory was all used up on my mc10001 - answer is delete some of your designs that you have put on your machine and gauranteed the next design you send via USB will be fine - no messages - woohoo im not going insane - sigh of relief. Anyway that is the solution - just delete a couple of designs and free up the space.
Cheers Jgurl
1helpful
2answers
Formating memory
You need to format the usb stick in the machine itself, don't use a high memory one or one that has a partitioned area. 1 gigabyte or lower. You need to use the set icon on the machine and arrow through the pages to find the Format screen. Select the tab for USB device. Then click yes to the prompts, that installs the correct folder system. Now the software end,open easy design and select machine from the top toolbar, set machine type to 11000. Open a design and use the file drop down menu and select Save As, choose JEF in the file type bar, you will see a button below Save , Delete, called options, click on it, you'll find a list of machines, set it for the 11000. It is that selection that saves the design in the correct format. There are 2 jef formats, the old Jef for the previous machines and the enhanced Jef for the 11000. Now rename the design, open the flash memory menu and in the right hand pane you should see your usb flash drive, if it's the only one you have connected all well and good, if not click on each flash drive to find the correct one.You'll know which one it is,because in the window below you will see an Embf folder, open it, you must always open the Embf folder before writing a design, now some have child files inside, emb, if so open that as well , don't create a new folder it wont be read by the machine. Now write the design to the usb flash drive. Do you have a copy of the PCtools software? if so you need to download the update as it's that software that allows 2 way communication between the machine and the computer. Keep an eye on how many designs you insert into the internal memory, it isnt very big. You shouldnt need to reformat the internal memory,
3answers
Janome MC 10000 with Easy Transfer using jef files
Your internal memory files could be full and need some designs deleted, the monogram design might not be centred in the hoop so it registers outside the sewing field, The hoop selected might be too small for the design.
3helpful
2answers
Cannot get Janome 10001 to read via USB direct link from computer
here's how I do it.
1. Get the design into jef or sew format (the only kinds janome reads). You probably already knew this, but some newbies try to use pes or art files.
2. Save it onto your computer (and remember the name of the file). I have a folder in my computer labelled "embroidery files" and then have subfolders dividing up those designs - such as animals, flowers, fonts.
3. Hook your sewing machine up to the computer via the USB cable.
4. Pull up your Janome "Easy Transfer" program (it came as a CD with your machine - this is NOT the customizing software).
5. Use that program to find your embroidery file. It's not going to show sew and jef in the same file - you'll have to switch back and forth.
6. On your sewing machine, click on the bottom button (under the screen) that shows the computer to the sewing machine (the third one).
7. Now click on the computer software "write to machine" or whatever it's called (it will be on the top tool bar).
8. Your file will be written to the sewing machine's memory and organized by the embroidery hoop size (A, B, C).
9. It will stay in the sewing machine memory until you use the cable hookup to delete it (reverse of the writing).
10. The 10001 software ate lots of the resident memory in the sewing machine - you can't store as many designs in it as the 10000 would allow. That's perfectly ok, as it only takes a few moments to move designs in and out of the machine.
To be perfectly honest, I vastly prefer doing the USB cable transfer to using the memory card jammed into the card reader deal. It's easy and quick.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
