Here's the method for the 11 cup model:
I have the 11 cup Kitchenaid food processor and did the same thing this weekend. It took a while but finally figured out how it went back together. Hopefully the pictures help. I know it's difficult to see since the pieces are all black. Good luck!
Testimonial: "Very helpful! I fixed it finally....after having ordered a new bowl ... but it doesn't hurt to have two..."
SOURCE: The plastic ? bowl of the processor is stuck
With the food processor I have it will not allow you to remove the bowl unless the top is off.Try take the top off or putting it on.Then remove it from the processor.
SOURCE: need a instruction book or manual for cuisinart 7 cup food proces
All manuals for models made in last few years are on Cuisinart website.
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
SOURCE: how to clean the handle of the 11 cup processor?
Try putting in the dishwasher, if you dont have one, try letting it soak in very hot water to sterilize it.
SOURCE: My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Testimonial: "really helpful thanks"
