Hi!
We can help. Check out our help centre to diagnoses the problem. https://www.generatorguru.com/need-help/
If you need more advice we can get you in contact with one of our Generator Engineers to guide you. We do not charge for this service and are happy to assist you throughout the repair.
Kind regards
The Generator Guru Team
Specialist Portable Generator Engineers & Parts Worldwide
www.GeneratorGuru.com
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
SOURCE: I have a new Generac 20KW Propane generator with a
Sounds like the electritian wired something wrong. Control wiring for that generator should be:
N1 and N2 = 240 vac utility input
Wire 0 = ground
Wire 194 (15B) = + battery
wire 23 = transfer signal
SOURCE: crankshaft seal blows out oil leak
The fix is replacement of motor!! I have the same problem and have already paid $700 in repairs to fix seal just to find out that the seal is being knocked out by loose crank shaft..Car had 60000 miles when I bought it 4 months ago, from a dealership, and now it needs a motor replacement..I stiil owe $5000 on a car that is worth $0..Dodge did not give the 100000 mile warranty they love to advertise on TV for the '06 Stratus..They only gave 36000 warranty because they did not think it would last much longer..Will never buy Chrysler product again!! They do not stand behind what they sell or they would have 100000 mile warranty on all their cars..
SOURCE: I was told I have
Well sometimes.... the front crankshaft seal is usually called a crank seal, or the front timing cover seal but the rear crank seal is (usually) called the Rear Main crank seal. In order to replace the rear seal , the transmission will need to be removed. If its the front, then the harmonic balancer will be removed. $380 sounds cheap. As you will need a oil seal, oil pan gasket, oil, filter, labor and tax. Maybe even a lower engine mount.
Testimonial: "Thank you sooo much!! This mechanic has been in business for 45 years and has been the president of an antique car club for many years..."
SOURCE: Iam looking to download a manual for a Kipor KDE
Try this link:
http://americanrvcompany.com/assets/images/Kipor/KDE5000ETA%20Operation%20Manual.pdf
