Question about Water Water Heaters
Titan n120, green light and red lights are on , water doesn’t get hot , ???
    Top Expert:
  • 935 Answers
While it could be many things that have gone wrong, the most likely cause is the heating element has failed. Call the local dealer.
Posted on Jun 15, 2019
SOURCE:
SOURCE: Titan-SCR2 N-120, water heater, need schematics
I have taken pictures and produced a wiring diagram for this model
Posted on May 11, 2009
snap101
  • 117 Answers
SOURCE: No green light on, power gets to unit but no light
did you dry fire it and burn out the fuse?
Posted on Oct 03, 2009
seanpwright
  • 2030 Answers
SOURCE: when turn on the hot water only the top red and
is it wired correctly..check all your wiring
if its a new install call the place of purchase or the manufacturer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Feb 06, 2010
SOURCE: my titan n120 puts out
Did you replace the Shower valve ? I would check to see if your shower has an anti scald valve. This could be your issue
Posted on Jan 14, 2011
SOURCE: scr2 titan water heater. No hot water. Both red
On the left side of the board there is a 10K 5Watt resistor that gets loose from the board because of overheat and it needs to core solder back with soldering iron.
Posted on Mar 28, 2012
I have a Titan SRC2 N120. the water is not heating.
Appears to be Electric. Check circuit breaker box first. If it is popped you may have a problem with installation. If it pops again
you have a serious electrical problem. Call electrician or installer.
Reset circuit breaker and still no lights or heat. Hopefully you have a warranty. If for some reason it "ran" without water, it has burned out the element. Unusual since there are sensors that verify water is moving.
Hope this helps.
Feb 27, 2015 | Water Water Heaters
Where is the reset button on a titan flomaster
were can I get repair service now Titan Scr 2 N120,In Spring Hill,Fl
May 15, 2014 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Scr2 titan water heater. No hot water. Both red
Apr 28, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
When turn on the hot water only the top red and green lights are on and the water is not hot
Feb 05, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Water Heaters Logo
101 people viewed this question
Top Water Heaters Experts
Fred Sops
Don Walper
Level 1 Expert
auntyjack
Are you a Water Heater Expert? Answer questions, earn points and help others
