Hi i have a 10 year old Frigidaire gallery CGLES389EB5 stove. i am getting error f30 i tried to change the temp probe it did not fix ti. i noticed after that more controls do not work like i cannot set time etc. BUT the stove top elements are working. any help would be appreciated : thanks nicholas
SOURCE: F30 Erorr on stove...
The fault code shows that your temperature probe opened.
1. Check resistance at room temperature & compare to RTD Sensor resistance chart.
If resistance does not match the RTD chart replace RTD Sensor Probe.
Check Sensor wiring harness between EOC & Sensor Probe connector.
2. Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. If you have already changed the sensor, I suggest checking the wiring or contacting a professional to move forward accurately. You can try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, once again contact a professional to properly diagnose the unit.
