Washing mashing overfills and wont wash but rinses and drains out
SOURCE: beko eco washing machine
Sounds like a pump problem. Could be a broken impeller, or something has got past the filter and has jammed it. Try removing the filter assembly inside, and see if anything is visible in the pump chamber. It may be too late and the pump is broken.
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
SOURCE: changing the brushes on a beko washing machine
Its been a while since I changed beko but here goes.......... Put the machine on its side (soapbox side down, This prevents excess water from the soapbox dribbling into the PCB and creating a further problem). There is an opening at the bottom of the machine in which you will see the motor. On each side of the motor will be the brushes each with a connecting spay-tag, gently take of the spay tag with long nose pliers (not grabbing the wire) and change the brush. VERY IMPORTANT.....each brush is angled and it is important you replace the correct brush eg. left hand brush to left hand etc. or else when you goto wash the next time you will simply hear a bang and have to price a new motor. I highly recommend when you take each brush off do it slowly noting its angle and replace the new one at the same angle. Wfen done replace the spay tag. I am presuming you know to do this when the machine is fully powered off and plugged out. Happy Fixing.
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
SOURCE: washing machine not spinning or draining water
its your drain pump if you can hear it humming but no water is draining it is blocked or jammed by a foriegn object (most probably a 20 cent coin or bobby pin/s), if you can hear it working as normal but still no water it may have a blockage sumwhere along the drain pipe either that or the impellor has snapped off the shaft and is ratteling around and not actually turning, and with the spin that is directly related to yor drain pump issue as the washer will not even attempt to spin if water remains in the tub, incredibly easy to do hit me back if you want detailed instructions
