Fills with water. Pump works. Drainage hose clear. Circulation pump starts.
Sometimes the inlet pipe filter is restricted. Although water flows into the machine it is on a timer and if not enough water enters the machine registers that it is low. To test this start the machine and after a couple of minutes open the door. Add about a litre of water and then close the door. If the machine runs full cycle it's due to either an obstruction in the inlet filter or in the inlet matrix on the left hand side ( remove top and left side panel to see this)
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
SOURCE: Bosch dishwasher not taking in water
May be open circuit water valve. Appliance will go to error mode if water level has not reached a certain height after a preset time. Check coil continuity with a multi meter. Should be looking for about 200 ohms.
SOURCE: i have a bosch dishwasher classixx its less than a
if its less than a year old why dont you contact the manufacturers service team it will still be under guarantee as the bosch guarantee is 24 months
you can dowload a copy of the instruction maual free of charge from the bosch or bsh home appliances web site
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
SOURCE: my machine is going through a wash cycle and has
Look for a kinked drain hose. Make sure drain hose is not plugged. Remove drain hose from washer and inspect drain outlet on washer is not plugged. Stick your finger inside and feel for any clothing fabric ect blocking drain line. The washer may have a built-in screen that is plugged. You may need to remove the back cover of the washer and inspect drain hoses for any kinks or blockages.
Hi
Intake/Drain light flashing means an issue while draining. The
dishwasher is not draining properly. Please check for air gap on the dishwasher
is not clogged. It prevents dishwasher from draining properly and sometimes the
drain flow is restricted due to gunk. Cleaning or bypassing the air gap will
resolve the issue. If this doesn't resolve the issue then it is due to seized
(or stuck) drain pump. Keep handy large bowls and towels to soak the water out.
Disconnect the power to the dishwasher or turn off the breaker to the
dishwasher. Tip machine on its back; remove screws that hold the bottom tray
on. Remove the hoses to the main motor, remove electrical connections and
switch it on. If the error still appears then turn the rotary selector switch
to "Stop/End" or press the "Start/Stop" switch for approx.
5 secs to cancel the error message. Switch the appliance off and then back on
again. Hope this helps...please post back for further assistance.
Daniel
