SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
SOURCE: not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
SOURCE: HSS25GFPA WW HOTPOINT REFRIG.
Please don't rate this solution because people generally don't rate well when it's bad news, even though the response is correct. When the DC evap. motor goes out, it can take out the motherboard. (located behind the small panel on back of the refrig.)
SOURCE: Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
