Question about Hotpoint Freezers
My Hotpoint fridgefreezer is freezing way below the recommended temp what cqn I do??
    Top Expert:
  • Hotpoint Master
  • 6,289 Answers
Thermostat is probably defective
Posted on Jan 27, 2019
  • 14,640 Answers
Inside the fridge is a adjusting knob.
Posted on Jan 26, 2019
2 Suggested Answers
SOURCE:
  • 1218 Answers
SOURCE: hotpoint ffa91g fridgefreezer wont go below -5
Good day,
If your talking fahrenheit, that is well within it's limitations.
Why would you want it any colder. -5 is fine. 0 to 4 is considered normal.
R134A runs at -15 degrees. It is considered normal for the box (any box) to run 10 degrees higher than the refrigerant.
When R12 (freon) was used it ran at -21 degrees, and could maintain a box at -10, but those days are long gone.
Posted on Jan 05, 2010
Hotpoint quadrio fridgefreezer keeps tripping the electrics when I open the fridge door.
I believe that a short circuit creates a defective light bulb inside the refrigerator or some other element in its circuit (door switch, lamp socket, wiring).
Dado
Apr 26, 2014 | Zanussi Freezers
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
Alarm has stopped working on hotpoint freezer fzs175g I have reset as per instructions but there is no light and no sound
We had a problem with ours, try setting the temp dial to off and then hold the super freez button for 5 secs, you should hear a bleep and hopefully all should be well.
Nov 27, 2010 | Hotpoint Freezers
Freezer doesn't work
my freezer defrosted it self and the red tryangle light stays on what is it
May 05, 2010 | Hotpoint 4.2 cu. ft. / 119 liter Upright...
Red light flashing
red light flashing means temp. is too high (not freezing) just an indicator to let you know that there is a problem
let me know: the freezer temp. (use a temp. reader)
any unusal ice build up on the back freezer panel?
is the freezer fan running?
compressor running?
parital frozen foods?
need to know so i can help you
Mar 05, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Hotpoint ffa91g fridgefreezer wont go below -5
Good day,
Jan 05, 2010 | Freezers
Hotpoint FFA071fridgefreezer
defrost carefully with a hairdryer taking care not to blow hot air on thermostats mounted on the pipework. this can take some time and don't use a knife to scrape ice off - use a plastic or wood spatula. appliance will still work for some time - week or two
to identify the fault is more difficult and you will need a multimeter. check continuity thro the defrost heater and the thermal fuse in series with the heater. check continuity thro any thermostats mounted on the pipework.. if these are all ok, then it points to a fault with the timer or main module
Aug 28, 2008 | Freezers
Freezers Logo
54 people viewed this question
Top Hotpoint Freezers Experts
AJMAL KHAN
Andrew Taylor
Andrew Taylor
Thomas Perkins
Thomas Perkins
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
