In Level 2 of Speed calibration mode, got about 10 loud beeps
SOURCE: pump stops running on high speed
You have a magnetek motor and it is overheating and cycling its thermal overload. A local electric motor repair shop may be able to fix it however it will likely need to be replaced. It is to costly to repair the motor if the damage is in the windings.
Assuming at that low a horsepower it is 115V, the likely replacement motor is a catalog #BN37. We sell it for $157. You are usually better off replacing the seal when you replace the motor and most Jacuzzi pumps are either a 200 or 1000. They should be around $5.
SOURCE: Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
SOURCE: Speed indicator and belt problem
Under the motor hood by the front their is usually a speed sensor either not working or not adjust close to pulley where magnet is locate in , when it passes by the sensor it should read it.
SOURCE: When i push the start
It could be just the sensor that has moved.
Refer to Page 22/23 of the Manual at the link below regarding the required gap.
http://dl.owneriq.net/b/bdc33f9b-8fa7-4914-8952-61e8fd49b637.pdf
If this doesn't solve your problem then let me know and I'll look into it further.
SOURCE: replaced speed sensor and calibration still fails, says there is no speed senosor
Call Treadmill Doctor at 800-750-4766 and they will walk you thru the install.
http://www.treadmilldoctor.com/?utm_source=fixya&utm_medium=CPC&utm_campaign=Mendi
