I want to make sure my printer is secure so that no unauthorized person can access, which has happened. I have changed my settings but I want to verify that this @JPL is not a problem.
SOURCE: Dell AIO 962 copy & fax issues
I'm betting the Cold cathode fluorescent lamp needs to be changed
SOURCE: I get error 0408 when i try to fax. Using epson
Communication error,try defaulting the machine ,check the line with a good telephone make sure you have dial tone.
Good luck
SOURCE: Dell 3100cn laser printer poor print quality
It sounds like you've got contamination on the drum cartridge or on one of the toner cartridges.
I'm actually going to be installing black toner in my 3100cn in about 8 hours, so I'll inspect and clean each of the carts, and write up the process for you tonight.
Testimonial: "Thanks! I have gone through all the instructions on Tech support for the printer. All cartridges have been cleaned and drum has been cleaned. Guess "
SOURCE: My epson workforce 600 printing
Try print head cleaning several times(3-4 times). Print nozzle check to see results. If the same problem-contact SC for deep cleaning.
SOURCE: My Epson Workforce 600 printer will not print
It appears that your printer is malfunctioning and will require service. Contact Epson and verify if your printer is still under warranty so they can replace it. Otherwise, have your printer check by the nearest service center in your area.
