SOURCE: slash / sign and other symbols
Hold down the shift button and press the letter V. Everything printed above the letters on the background of the keypad can be printed by holding down the shift key and pressing they letter key.
Hope that helps.
SOURCE: Songs will not play....
I have same model but no problems. had older model w/ same issues. try holding menu button and center button at same time for about ten to twenty seconds to reboot. that might clear up the bug.
SOURCE: upgrade my hyundai 98-pro edition karaoke player
upgrade is not a solution you can buy a hardisk player for mtv viewing just separated with your hyundai 98-pro player in one tv....just go to
the qualified technician for more info at the electronics center.......
SOURCE: how to repair a cannot read hyundai karaoke player premier 98i
If it isn't reading any discs you can try gently cleaning the laser eye with rubbing alcohol or isopropyl alcohol and a cotton swab. If that doesn't work the most likely culprit is the laser assembly. This means replacing the cd mechanism.
