Health & Beauty Logo
m
mary l cann Posted on Jan 26, 2019
Pride PSK 651. What causes it to be stuck in reclined position?
5 Related Answers
gnshome
  • 31 Answers
  • Posted on Apr 07, 2011
SOURCE: Invacare power chair model #1089384;
Hope you have had this fixed by now. But in case not and you are not able to use the chair.
If the chair still drives it's not batteries. The toggle switch box should be ok if there is no visable damage to it. Bad connections of the wiring from the toggle switch box to power or the recline or tilt motor should be inspected. A electronic tech is needed for most electronic failures.
Anonymous
  • 1622 Answers
  • Posted on May 02, 2011
SOURCE: MY CHAIR IS IN THE RECLINING POSITION AND IT
The best thing to do in this situation is to call the vendor and have them repair it under warranty. There should be no charge for this service since the chair is brand new.
There are some checks you can make to avoid a service call. You have checked the batteries and hopefully the chair is plugged into the wall outlet. It is possible that something got disconnected under the chair. To check this you need to flip the chair over on its side or on its back since the leg rest scissor mechanism is extended. Look for any plugs that have come apart at their connections. Check for a pinched or binding scissor mechanism or tilt frame parts.
You should not attempt this at all if you cannot safely move a large piece of furniture. Perhaps a friend or relative may be able to help.
Insist that the vendor honor their warranty commitment ASAP. If you paid with a credit card, you should contact your credit card company to put the amount in dispute if the vendor is unresponsive. Hope this helps.
And you can troubleshoot with the below instructions if it with also help
things you'll need:
* Pride chair Owner's Manual
* Screwdriver
* Wrench
* Pliers
Instructions
Look at the chair's electrical plug, as the chair most likely became unplugged or the plug is not fully connected to the outlet. If this is the case, securely reconnect the plug.
Check the chair's connections. The electrical connections under the chair could be loose or connection cables could be pinched or bent. Tighten loose electrical connections with a small screwdriver and straighten bent or pinched cables.
Check the chair's transformer, motor and relay box under the chair as a malfunction in any of these could cause the chair to stop working completely. The hand control used by the operator to change the chair's position may also be malfunctioning.
Test the chair's wood frame, bolts and lift frame. Loose wood frames or bolts, overly tight bolts or the lift frame rubbing against the wood frame will all cause the chair to squeal.
Lay the chair on its side and check the wood frame and t-bracket. If the wood frame is rubbing against the lift frame or the t-bracket is cracking, you could hear popping noise. The t-bracket is the metal frame on the underside of the lift chair.
Check the dual motor timing if the chair will not recline all the way. The motors' timing could be off which would stop the chair from completely reclining. Put the chair on its side and remove the motor and plug it in. Use the hand control to turn the motor on and let it run until it stops on its own. Screw the push tube, located to the right of the drive tube where you just removed the motor, until you feel it bottoming out. Turn the push tube back two turns and grab the push tube. Turn the unit on with the hand control and allow the push tube to move away from the metal casing. Push the pin at the back of the push tube and reinstall the motor. This should re-time the motor.
Look at the wood frame, seat foam, leveling legs, motors and bolts if the chair is crooked. The wood frame could be twisted, the seat foam may be broken or misshapen, the leveling leg may need adjustment, the motor could be timed incorrectly or the bolts could be loose. If all looks in order, make sure the ground under the chair is level.
Unplug the chair before you begin fixing the chair.
Restore power to an inoperable lift chair. Ensure the circuit breaker box is connected to the electrical outlet. Make sure the external transformer is plugged directly into an electrical outlet.
Fix a Pride lift chair that only operates in one direction. Use a cotton swab to remove dust and debris from the toggle switch on the hand control. Flip the toggle switch back and forth to loosen any remaining debris which may be causing an obstruction.
Fix inoperable heat and massage features. Check the LED lights on the hand controls; the LED display is not lit, hand-tighten the connection between the hand control and the lift chair. Make sure the the heat and massage units are properly connected to the back of the lift chair.
A
Anonymous
  • Posted on Jun 12, 2012
SOURCE: HONDA ACCORD Seats Front Assembly Recliner went down and won't go up
I wouldn't ruin anything by trying things yourself
I would have a dealer check it out
The dealer I used in the past, has a seat specialist come
in on Wed only, around 5:30 after the service bays close
& one service writer hangs out until that person fixes a
couple vehicles seat issues
Anonymous
  • 3 Answers
  • Posted on Dec 16, 2012
SOURCE: I have a quantum 600
I'm having the same problem with the red light on my Q6000Z PC not going out, no matter what position that the seat is in. Yesterday I lifted the seat to change my furnice filter and when I lower the seat light wouldn't go out and the chait would not move. and yes I did try going up and down several times. I do have a Quantum joystick controler, but I don't know how to use it. Can anybody help me? Or at least give me a website name where I can go to fond out.
Julie Clark
  • 266 Answers
  • Posted on Oct 12, 2014
SOURCE: I have an electric recliner chair that is in full reclining position.Is their a manual release somewhere on the chair to put it back in its upright position?
http://shop.panasonic.com/shop/model/EP790K?t=manuals&support
There's the manual.
06 tribeca seat stuck in recline position how to fix?
Check fuses first. Then check switch operation and then wiring harness to recline motor. If recline motor is bad, remove the seat to access
Lincoln MKX passenger seat stuck in reclining position
Hi. Thanks for your question. Check all the fuses first and then look under the seat to see if something has stuck in the track assembly. You might find that the wire connectors have disconnected from the seat switch somehow. However, you can also visit https://www.reliable-store.com and download the entire workshop manual for better understanding. It has all the information along with the diagrams which are really helpful. Good day!
07 Ford Expedition passenger seat stuck in recline position . Has power to it when I try to put it in upright position it moves slightly but it seems to be stuck
If it's binding the circuit breaker will shut off the recline motor. You have to replace the entire back frame to replace the motor
Flexsteel electric recliner positioned itself in full reclined position and is now stuck there. Help!
It seems that you have a short in the chair control. You should be able to get a replacement from the manufacturer. They can be contacted at http://www.flexsteel.com/home-furniture/customer-service/contact-us
Sep 09, 2014 • Furniture
My wheelchair's green light doesn't come on after I return from my reclining position
Contact Pride for a manual, you'll need one. Or a Wheelchair/ medical equipment outfit.
Nina power recliner chair stuck open
Look where the control button is it should be a little space to where you can stick a needle or nail in that the reset button I want you reset it then you should be able to get to a recliner to go back down
Passenger seat stuck in lying down position.
Use some penetrating lubricant on all pivot points and levers around the recline mechanism, and let the lubricant sit overnight. In the morning, try to work the recline mechanism free. (The vehicle is quite old at this point, and likely parts in the interior need lubrication. These parts should be lubricated annually.)
2helpful
Front seat stays in the reclined postion..
The seat position is changed through the use of a cable that runs through a flexible tunnel, under the seat. In one case that I'm aware of, this cable got stuck around a projecting seat spring under the seat. When the seat was reclined and moved backward or forward, the cable caught on the seat spring and the seat had insufficient slack in the cable to release from the reclined position.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
