Make sure time is set
SOURCE: A/C unit continously running even though turned
Check your wiring behind the thermostat. If you have two wires touching, it will cause this. If everything is ok. Check inside blower compartment for the low voltage wiring. This is your wiring from your thermostat. Make sure none are touching. This would typically be your yellow wire that controls outside compressor.If not any of this you need a new stat.
SOURCE: my fan continues to run even though the heating
Check the fan relay and make sure it is working properly. It might be stuck, which is the most likely problem
Testimonial: "Although I have not had the fan relay checked, it is something I can suggest when I call the repair person. Thanks"
SOURCE: Cloudy water after running system for 15 hours
yes ... do you have filter media insyalled and the proper amount of salt installed?
