The whole does not look available. Can you just order parts to fix the door you have?
https://www.partselect.com/PS1964481-Whirlpool-W10162566-DOR-FIP-US.htm?SourceCode=3&SearchTerm=w10162566
SOURCE: Maytag French Door Refrigerator with ice and water on the door
See the post on Samurai Appliance Repair Man's site http://applianceguru.com/forum1/13035-1.html for instructions on how it's possible to fix the HV Controller Board power supply filter caps for $5 in Radio Shack parts (really!). You need to be able to solder electronic components, or know someone who can. There are 2 power supply filter caps that appear to go bad and the result is the blinking and flapping. I had the same problem and decided I could not wait for a $150 replacement back-ordered board.
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
SOURCE: ice maker not filling with water
I have a model KSRG25F and found that the solenoid that controls the water to the icemaker was not working. I tested by switching the water dispenser connection to the ice maker coil.
And then had the wife push the water fill in front of the fridge. I had aready changed out the control board in front because I didnt have the flash codes or solid led when simulating door closed. the parts is about $55 and hope that does it. Good Luck
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
repairclinic.com
partsselect.com
directly.
in refrigerator?
refrigerator?
These will help.
Thanks,.
directly.
in refrigerator?
refrigerator?
These will help.
Thanks,.
repairclinic.com
partsselect.com
directly.
in refrigerator?
refrigerator?
These will help.
Thanks,.
