SOURCE: kodak easp 5 paper jam
Greetings Thurnwood,
Sorry to hear about your trouble.
First thing I would do is check the printer to be sure you have removed all packing tape, and that any supply space is clear. If there are more than one resource locations for paper, be sure you have them in their correct positions.
Unplug the printer from your computer, and turn off the power. Leave it off for a couple of minutes then turn it is on. Do not connect to the computer but insert some paper and try printing via the stand alone option. Make sure you have calibrated the printer and that the print head and ink are installed correctly.
If none of this works, please call our 800 421 6699 and our team will make sure you are printing in no time flat.
Good luck, I will be around to see how you make out.
Best Regards,
Ron Baird
the friendly Kodak guy
SOURCE: ESP 7 paper jam error
I had the same problem, but after pressing the OK button when the paper jam came up again I pressed the CANCEL button and was able to print my document. See if that works for you too.
SOURCE: kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
SOURCE: Printer Jam. We have a Kodak Esp 5200 Series.
Try removing the gray cover on the back of the printer to remove the paper.
SOURCE: I have a paper jam inside my new ESP 7250 printer.
maybe just a very small piece of paper, look carefully on the paper path
Testimonial: "Thanks!!!!"
