I adopted my two nieces and parental rights were terminated, got subsidy for the two girls. I also have a nephew that is brother to these two nieces, he was not adopted, now I am asking help from the ISD office and now they want me to cooperate with child support, which is not problem, however, they want also the information for my two nieces. Why if I am just asking for help for my nephew?
Hello, Sandra -
I suggest you pose your question to your contact with the ISD office. You have not indicated the US state where you reside, so it is not possible to check the laws and state agency rules which would apply to your situation and that of your nephew.
You may also wish to seek out the assistance of a family law attorney in your area regarding your situation.
Note: Fixya.com, where you have posted your question, is a website intended for asking and answering questions about how to go about REPAIRING THINGS. I chose to answer your question as a kindness.
Best wishes.
SOURCE: quattro pro x3 abnormal program termination
1. Click Start, Programs, Accessories and Run.
2. In the open window, type: regedit and click OK.
3. Choose the following path
HKEY_CURRENT_USERS\Software\Corel\User\Assistant\13\Recent Work\Quattro
Pro\
4. Right click on the Quattro Pro folder, select delete.
5. Say yes when prompted to delete the key.
6. Close the Registry Editor
7. Launch Quattro Pro
This key will be re-created when you reopen Quattro Pro. I ran into this problem when when I tried to open a QP SS on my hard drive after previously opening one from my thumb drive. Now I copy to my hard drive first.
SOURCE: Wingdings prints on Brother HL2170W
When printing using Terminal Server, the print driver needs to be installed on the server itself. If you have a printer that doesn't have the driver installed on the server, it will either not print at all or it will use the "fallback driver", which is something set by the person who administers the server. Thus, it may be trying to use an HP driver to print to a Brother printer, which won't work. Ask the administrator to install the Brother driver on the server and it should work at that point.
SOURCE: I've got 3 L230 Terminals all ask for a password I never set.
try to add users with password on your windows 2003 server first and test and see if this resolve your issue you c
SOURCE: Terminal Block
terminal was loose started arcing like a welder causing heat to melt the block
SOURCE: I can't figure out how to wire my cooper wiring
Take the black going to the light off the center and hook where the white going to the light is now....then hook the white to the light with the other white and you will be good to go...You almost had it right...
just a couple of adjustments....:-)
heatman101
