Question about Amana Kitchen Ranges
Amana ACF7225AC door won't lock on self clean
    Habit-Forming:
  • 55 Answers
Try disconnecting the power to see if it will reset. If that does not fix it, it will probably need a main board, but more testing needs to be done to know for sure.
Posted on Feb 09, 2019
Testimonial: "Yeah, did a power cycle first thing. No help. Further testing found a bad latch motor. It was getting power to the latch motor but motor did nothing. Latch motor no longer available, so I'm stuck with replacing the range just because it it won't self clean."
  • Tom C
    Tom C Feb 09, 2019
  • Tony Marley
    Tony Marley Feb 12, 2019
    I looked for a latch solenoid too and there are just none to be had.
SOURCE:
SOURCE: Amana stove stuck in 'lock' mode, door won't open
try hitting cancel is it displaying any error codes like e2 f3 try turning the breaker for five seconds then back on
Posted on Dec 28, 2007
SOURCE: jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Posted on Mar 21, 2008
  • 10865 Answers
SOURCE: self-cleaning oven door won't open
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Posted on May 20, 2009
SOURCE: how do I clean my amana gas self cleaning oven
I have an Amana self-cleaning oven, Model AGR5715QDQ. I can't find my manual - how do I start the process of cleaning? Elizabeth
Posted on Nov 22, 2009
mrbobfixit
  • 259 Answers
SOURCE: Oven sef clean latch locked but door is open and I
Ok. Open the door and find the oven light switch(es) (some models had two switches). Press the switch(es) in and see if the latch goes back to the home position. If not enlist a volunteer to turn on the self clean cycle while you are holding the switch(es) in. Just after the self clean starts have them hit cancel and wait until the lock comes back to it's "home" or unlocked position.
Good luck!!
Posted on Jun 16, 2010
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
Oven door won't lock, self clean won't start
this is a door lock error , you will need to replace
Feb 20, 2013 | Kitchen Ranges
We have an Amana Easy Touch Control 500, the pilot is on but oven won't heat up. We also can't self-clean because the door won't lock or sometimes it locks and won't open. I suspect the...
Most likely the door for your kitchen range has a sensor that is not allowing it to heat up because it detects that the door is not closed.
I would suggest you consult help from a certified technician by the manufacturer of your Kitchen range that way they would also be able to check other possible faults on your kitchen range and replacement parts would be 100% compatible.
You can also check the services that these guys offer:
http://www.stoverepairnearyou.com/ml2/?v=1640662349&u=08E0B192DFA88BAA0210818080F80718DDA9032090DEAEEC8F8CA8CFC401
Hope this helps!
Jul 18, 2011 | Amana ACF4225AS Electric Kitchen Range
Oven door latch does not lock - I was told part no longer available
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
May 07, 2009 | Amana ACF3355AS Gas Kitchen Range
Amana Oven Door won't open. Latch to lock it is broken.
After pressing Self Clean, Adjusting the Time and Pressing Start, the self cleaning cycle shows the # F57_ on the read-out. I tried to cancel and now the door opens, but I can't get the Bake to begin when I press Start. No matter what I press LOC flashes on and off, but the door is unlocked and the heat is off.
Please help!
Susan, PR
Apr 17, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven door is locked
the oven door should only unlock the door when it deems the temperature a safe temperature.. there are 2 other possible reasons.. the door lock motor could be bad.. or the control is bad.. you would need an electric volt meter to test to see which it is.. if you need further assistance please ask b4 rating
Apr 09, 2009 | Amana ACS7270AS Electric Kitchen Range
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Trying to use self cleaner, and the door will not lock.
bad door switch or latchmotor or one of the micro switches that control it or not following proper procedure for self cleaning
Mar 02, 2008 | Amana ACF3355AS Gas Kitchen Range
Dec 28, 2007 | Whirlpool RF378 Electric Kitchen Range
Kitchen Ranges Logo
59 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Paul Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
