SOURCE: feed dogs on serger don't advance
I use my BLSE200 all the time and ran into the same problem just last week. After pulling out my hair in frustration, I finally realized it had to do with the stitch length. Something wasn't connecting after I adjusted the stitch length, so when I re-set the stitch length, it popped things back into alignment and the feed dogs started working again. *whew* Hope that helps!
SOURCE: I have a singer 6110 machine & the fabric feed
Unplug the machine, turn it on its back and undo the base cover......there may well be a load of shredded teeth from the timing gear .... it is not impossibe to have this repaired, but ask for a quote and see if the money would be better invested in another machine.
SOURCE: feed dogs dont move fabric thur
Have you changed the stitch length selector to zero ? If there is no lint trapped under the needle plate between the feed teeth, then the length selector is likely set too small,.
SOURCE: I lost my instruction manual fro my serger white
I found a free pdf manual for my 20 year old White serger at singerco.com. Hopefully you can find yours too.
I have the white superlock 2000, if you still need intructions, let me know
