Dehumidifiers Logo
Shaun Alger Posted on Jan 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I owned a Keystone in the past. loved it. just purchased 2 more. NOW - for some reason - they don't shut off when bucket is full. will actually OVER fill and leak. how fix ?
Ransom F.
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Jan 30, 2019
Ransom F.
Expert
Level 2:
New Friend:
Answers
51
Questions
Helped
12122
Points
127
Dehumidifier typically use a float in the collection bucket to detect water level and automatically shut it off once it's full. Have you checked to see if the float is broken or missing? Also sometimes it can get stuck ir jammed up when inserting the bucket, make sure its in place and falling freely down into the bucket.
4 Related Answers
Anonymous
  • Posted on Aug 26, 2009
SOURCE: dehumidifier leakage
i have the same problem, trying to figure out how to fix it. maybe i will try some tape too
vasto
  • 3 Answers
  • Posted on Sep 28, 2009
SOURCE: Bucket fills but unit will not stop dehumidifying.
Duct tape a weight ... 1 inch bolt to float assembly.
Anonymous
  • 15935 Answers
  • Posted on Sep 04, 2010
SOURCE: Dehumidifier won't drain
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Anonymous
  • 1015 Answers
  • Posted on May 30, 2011
SOURCE: Have model FDL70S1 that is
It is possible that your hose has a build up of algea in it that has started to jell. The water you are removing from the air is very pure and allows this growth. I would remove the hose and clean by blowing through it or hooking it up to faucet and flush it out. If you can get it open then running a cup of bleach thru it on a regular basis will stop this from happening again.
2answers
Drains through hose and into bucket
this happens when the drain tube becomes blocked so unit overflows and water falls into bucket and not flows out tube , clean tube and drain port with compressed air (wear eye protection!!!)
How can I purchase a replacement air filter for keystone kstad70b?
The filter in your Keystone KSTAD70B is meant to be washed. It is not listed as a replacement part in the owners manual. This is copied from the manual:
3. Clean the air filter
Remove the filter every two weeks based on normal
operating conditions.
Remove the filter from the top of the unit (See.Fig.11a),
or to remove the filter,remove Bucket then pull filter
downwards (See.Fig.11b).
Wash the filter with clean water then dry.
Re-install the filter,replace Bucket. CAUTION:
DO NOT operate the dehumidifier without a filter
because dirt and lint will clog it and reduce
performance.
If you have lost or destroyed the filter, go to Amazon and order the Duck Brand 1285234 Replacement Air Conditioner Foam Filter, 24-Inch by 15-Inch by 1/4-Inch, 1-Pack for 96 cents with free shipping as an add-on item to any order. It is also washable so you will be able to use it like the OEM filter material.
Fedders a7dh45b2a*a-r dehumidifier shuts off before the bucket fills
Actually, it's probably doing what it should. Let me explain: Dehumidifiers run until they have lowered the humidity/moisture level to where you have the humidity extraction level set. At that point, the unit shuts OFF, until senses the humidity level has risen above where you set the level and it turns ON again. That doesn't mean the bucket will always be full when it shuts OFF. It may turn ON & OFF many times before the bucket is full. Watch for the Bucket Full Light to illuminate. That's when the bucket is FULL and needs to be emptied.
Hope this helped you understand how the unit works.
I am not sure of the exact model number, but the unit is rated for 70 pints. It shutdowns and lights the full bucket lamp, but the bucket is not full (there is a hose attached). I dis-assembled the unit...
The problem is that the hose connection tube that the hose is connected to, is clogged. That's the reason water was going to the bucket and the full bucket sensor was shutting the unit OFF
To unclog the tube, you will need an 18" long Plastic Zip Tie or something similar (NO Wire Coat Hangers, though) that is appropriately sized to fit into the hole. Before doing anything, Turn the Master ON/OFF Switch to OFF and unplug the unit.
Carefully insert the Zip Tie into the hose connection hole/tubing and continue to gently push it in, until it reaches the bend in the tubing. You will need to gingerly work past this bend, until it bottoms out or you run out of usable Zip Tie. Now, slowly remove it, while rotating it. This will dislodge the clog. As the Zip Tie is almost totally removed, be prepared for some water to follow.
The above should solve your problem. Will you still need the wiring schematic to reconnect the bucket safety switch? If so, please let me know.
2helpful
New Delonghi Dehumidifier,5 gal:When units beeps that bucket is full,what are exact steps to do 1st:empty bucket, then press what button to restart?or does it restart on its own?
It should resart on its own after putting the empty bucket back in. The beep is to let you know that the bucket full and it shuts off the humidifier until the bucket is emptied and put back into the proper position.
Top Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Dehumidifier Expert? Answer questions, earn points and help others
