Hand Tools Logo
Marsha Brown Posted on Jan 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screws aren’t regular screws. What tool can I use to get them out
  • Jean DeLauche
    Jean DeLauche Jan 24, 2019
    Hello, Marsha - What is the make and model of your car or truck? Plus, what part in the car or truck are you trying to remove? I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • David Shaub Feb 19, 2022
    Harbor Freight sells a security screw driver bit set that has multiple types and sizes of oddball screwdriver bits. There are flat, phillips, torx, torx security with a pin, 2 hole, clutch or butterfly, 3 sided and a few others. There is also a set with bit holders. The kits are very reasonably priced.
brett meldahl
Level 1:
Habit-Forming:
New Friend:
  • Contributor 32 Answers
  • Posted on Mar 19, 2022
brett meldahl
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
32
Questions
Helped
11154
Points
95
Don't drill, don't cut, don't do anything u til you take a picture of the fastener and either post it here for identification, search it on Google lens or take it to a hardware store and have them sell you the right tool for the job.
john h
Level 3:
Top Expert:
  • Master 29,494 Answers
  • Posted on May 09, 2019
john h
Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7553573
Points
193449
What do they look like their are square -torx -one way -and security [ a pin coming up in middle] are a few type --can drill and yae extractor --cut groove and unscrew - grind off
luv4shorty
Level 1:
Habit-Forming:
New Friend:
  • Contributor 8 Answers
luv4shorty
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
8
Questions
0
Helped
8856
Points
12
Buy a drill bit tip kit... it will have various tips for all types of screw heads. Surely there will be on in there that fits
Kyle DeLory
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Apr 24, 2019
Kyle DeLory
Contributor
Level 1:
New Friend:
Answers
18
Questions
Helped
38344
Points
44
Depending on what screws you can cut a groove with a cut wheel just deep enough to allow you to remove the screws with a flat head screw driver especially if you are dealing with one way security screws
Chris Huff
Level 3:
Top Expert:
  • Master 6,289 Answers
  • Posted on Jan 24, 2019
Chris Huff
Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2019185
Points
74913
Probably torx although we have no idea what your referring to
3 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 04, 2008
SOURCE: oil pan replacement
Buy a special thin walled socket from Snap-on tools.
Anonymous
  • 90 Answers
  • Posted on Dec 25, 2008
SOURCE: Disc Brake replacement
You need an impact screwdriver. You should be able to pick up a cheap one from your local parts store. You hit the impact screwdriver with a hammer and it forces the screwdriver bit to turn. But make sure you are using the correct size bit, or youll strip the screws and itll be a pain to get them out.
Anonymous
  • 13 Answers
  • Posted on Jan 06, 2012
SOURCE: What tool do I use to core out a phillips screw head
Try drilling them witha metal drill bit
How to tighten the handle on an upright Kenmore freezer - model 970-187020
That model will not come up on the Sears site so I can't look at the picture breakdown. If the screws you see are tiny ones in the sides of the handle, then they are called set screws and require a small allen wrench which is a 6 sided L shaped rod. They usually come is a set. Can be purchased at Sears or any hardware/ tool store.
How do you replace the fan blower switch
Remove all screws, if any, around the radio and a/c controls. Carefully pry the bezel around the radio with a pry tool. Try not to use flat tip screw driver or you may put marks on your dash. The whole bezel will unsnap. A/c switch should be exposed with screws holding it. Remove screws
How to remove the funny shaped screws on microwave
ANTI-TAMPER SCREWS
If your model has anti-tamper screws, you can remove them using using a T20H Torx type or GTXH20-100 screwdriver. If the correct tool is not available, there are several ways to remove the screws:
- Use a hammer and a small punch or similar tool to knock out the middle post of the screw, then use a standard T20 Torx bit to remove the screws. (Use safety glasses).
- Insert a small flat-bladed screwdriver (such as a jeweler's type) into the slot between the post and the edge, tap the screwdriver firmly with a hammer to loosen the screw, grip the screwdriver with pliers, and remove the screw.
This detailed photo shows how a small screwdriver fits into the screw head:
- Use a hacksaw or Dremel tool to cut a slot in the head of the screw, then use a flat-bladed screwdriver to remove the screws. (Use safety glasses).
Cant get the door panels off
After you have removed any concealed screws (there normally aren't many), there will be plastic snap-in fasteners some of which will break when removed. You can buy a simple pry-tool at auto parts stores that can minimize the damage when removing the panels. The fasteners that break are generally available at auto parts stores as well and easy to replace.
I have a 1998 Ford Windstar and the turn signals aren't working. I have already changed the fuse and checked the bulbs. Please help!
Replace the turnsignal switch. These are not hard in fords. Remove 3 or 4 screws on the bottom of the column bezel, remove it. 2 or 3 screws remove the switch.
How dose the case come apart
usually with LCD monitors there aren't many screws holding them together, instead they are held together with plastic tabs. You need to remove any screws holding it together (if any) and you need to pull the case open with a butter knife or a special pry tool (flat head screwdriver wouldn't be a good choice because it leaves more marks). you need to insert the knife or whatever your using and pretty much pull it apart gently, this isn't easy to do and you can risk ruining the whole screen if your too aggressive when opening it. unless your trying to fix the monitor, you shouldn't open it because it usually will look like **** afterwards.
Oil pan replacement
2answers
Top Hand Tools Experts
john h
Larry Ng
Larry Ng
Ziyaad Khan
Ziyaad Khan
Level 1 Expert
Are you a Hand Tool Expert? Answer questions, earn points and help others
