Washing Machines Logo
Andrew Wilson Posted on Jan 24, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore washer Model 592-4900 Replaced door switch & pressure switch. Tried Express wash. It went through the cycle. Pumped out approx.90% of the water then stopped. Got Error No Draining.
Android Man
Level 2:
Sergeant:
  • Expert 278 Answers
  • Posted on Jan 28, 2019
Android Man
Expert
Level 2:
Sergeant:
Answers
278
Questions
0
Helped
57779
Points
817
Hi Andrew, please give full model number. is that a front load washer?
4 Related Answers
Anonymous
  • Posted on Jan 05, 2009
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Anonymous
  • 4 Answers
  • Posted on Sep 12, 2009
SOURCE: kenmore washer model 82980120, stopped working
Check the sound of a CLICK when you close the lid door. If you do not here it then it's your LIMIT SWITCH that is broken. I had a similar problem and to get my water out quickly I removed the cover that wraps the washer and removed the limit switch and joined the two wires together so that the machine thinks the lid it closed. It is not a safe thing to do but it gives you time to go buy a new one in the mean time you can continue to do your washing. Just remember that when you open the lid door your washer will still SPIN on it's RINSE and DRAIN CYCLE. be very careful if you have KIDS. I hope this will solve your problem.
Anonymous
  • Posted on Dec 09, 2011
SOURCE: Kenmore 90 model 110.20912991 wont stop filling with water
On my kenmore 90, I found out that when putting back the cabinet, the hose that is connected to the load size selector was pinched... probably affecting the vacuum/pressure. Re-assembling the unit ensuring the unit was not longer pinched solved the problem.
lpfaff1
L Pfaff
  • 11573 Answers
  • Posted on Mar 06, 2016
SOURCE: Kenmore front load clothes washer fills with water and stops. No error code and door is locked. 2007 model, we tried unplugging and draining. We can't see model number because door is locked. Help!
Justin, check or by pass the lid switch if it has one, with a insulated jumper wire.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kenmore 600 Series won't spin after wash cycle
the clutch should be checked for wear by spraying water from water bottle on it when you run the spin load and it should not show any steam or sizziling, you can also remove the clutch and try to hand spin the inside while holding the body it should not be able to spin easily, should be difficult to move. should be a tight fit, im sending more pics but fixya giving me problem s sending them, also check the motor coupler for damage or broken pieces on floor.
also test the door switch by jumpering it,
2answers
If it continues to fill turned off or even unpluged, It needs to have the water valve replaced it is sticking open.
2answers
Kenmore Front load washer didn't complete the cycle.model #44082
Do you still have your owner's manual that came with the Kenmore washer? Look under troubleshooting your Kenmore washer.
15helpful
3answers
1helpful
Won't spin
check your lid switch ...on the lid you see a little plunger this should go into a slot areound the rim of the washer and close a switch. you can try a small screwdriver to press it in while in the spin cycle..see if it works then if not the sw will have to be replaced as this needs to be closed (lid) before the unit will pump out and spin
Kenmore 90 Series, washer Model 24924200
probably a sticky or broken bearing clutch, call a repairman. Probably be under 100k dollars to repair.
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
I have a kenmore model # 110.26934691 / 90 series
Check the warm and hot cycles. If they work then the pressure valve needs replaced. Disconnect the watert hose to machine and make sure water comes out. Back screens may be clogged also.
Alexander
vince
