SOURCE: replacement foot pedal and wiring for Euro Pro
Here's a place that carries all the pedals. Many are used by various brands, and go under different names for different machine companies. The euro-pro manual has the manufacturer's name and the model #, or you can browse the drawings of pedals to match your own. My euro-pro 9110 uses a model also used by viking and huskevarna. This place carries the cords as well.
Good luck.
http://sewingmachine221sale.bizland.com/store/page36.html
SOURCE: euro pro shark 7132l no foot pedal/power cord
Sewing Service shops often have old foot control pedals from retired machines, so widen your local search and don't just look at Europro, as a good tech will service all makes.
SOURCE: Necci Lydia mk2 544.
try cleaning under the needle plate where the feed dogs are to get out any lint or loose threads
then clean the bobbin area for lint or loose threads
rethread the machine- top thread & bobbin--make sure to thread every thread guide
make sure the thread moves smoothly around the tension dial
also check the top tension setting -usually 3 or 4 is good
make sure the power cord is inserted correctly into the machine
it could also be the foot pedal itself may be going bad--it would have to be checked by a repair shop
always use the same thread on top & in bobbin area
put new needle in also
also some thread & needles are not compatable--try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
SOURCE: megabind 1 binding machine comb opener is stuck
Leave a comment if you need more help.
Thanks for using Fixya.
