SOURCE: Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
SOURCE: how to do the clean
Hi Good day!! try this method
- Machine off
Switch on the machine while holding down the "menu"button until all the
leds are flashing on/off. Now you are in "maintenance" mode.
- press 80
- press the "mono start" button several times until you see "purge: xxxx"
- press "2783" in order to reset the purge counter. You will see: "purge:0000"
- press "99" to exit the maintenance mode
Now
you are able to print again, but actually your ink absorber box is now
full with ink. Ink flooding can happen if you don't replace this ink
box!
Don't forget to vote thanks!!!!
