Toshiba tv model - 49L621U
SOURCE: toshiba 65hm167 black screen with video input
That is correct, if the lamp was bad then you will not see a picture at all. The fact that you are getting menu means the lamp is good and most likely the processor and light engine are also okay. Check other inputs to see if you have the same problem on all the inputs.
SOURCE: NEW Samsung LEd TV does not recognized older Toshiba VCR in sourc
Hello callkaren2,
Electronics are so much fun arent they?
The TV does not need to recognize the VCR at all. All it is looking for is a plain Composite video signal from any device - VCR or DVD.
If you are just playing a tape and not using the VCR as a Tuner, then it doesnt matter if the VCR is on Chl 3 or 4.
Do this - play a tape, test the Yellow connector to a regular TV to verify the signal is coming down the cable. Then, try it again on another Video/Yellow input on your LED unit. Have a great day!
Cheers
SOURCE: Toshiba model number 62HM95 62' makes grinding noise
SORRY, This is from the authorized Toshiba parts center:
"The color wheel, lamp fan, lamp fan holder are parts of the LIGHT ENGINE only." It means the wheel is not sold separately and there is not even listed in the breakdown for the set a part number.
A replacement light engine (optical light engine) retails for 456.00 list and is sold on an exchange basis only.
SD TECH
