Rinse your hair with plain vinegar as a last resort if your hair color is still too strong. Vinegar is acidic and can help strip dye from your colored hair if used correctly. Apply enough vinegar to thoroughly soak your hair, and allow to sit for two or three minutes; then, rinse with liberal amounts of warm water.
Apply shampoo and wait 15mints then wash 2days will be clear.
SOURCE: I dyed my hair Using
Use no more than an inch of the cool mix tones to the 10a next time... You just used way too much. Or try one of the Wella toners!
SOURCE: It is printing bright blue streaks all over the
Forget the answer above, this printer is a laser jet and dipping anything in water will certainly stop it working.
SOURCE: I have naturally dirty blonde
If you have a beauty supply store near you, like Sally's, purchase Roux Fanci Full Styling Mousse in one of the blonde shades to tone down the red. This product works really well and provides a wide variety of colors,
SOURCE: hello! i used the bright
ok honey, first thing is don't freak, you will be ok. the only way to fix this is to go darker. with out a picture I'm going to do my best to help you. See if you can get a friend to help you do this. You will need to put the hi-lites in foils, try to get as much of the blond and as little of the orange as possible in the foil, coat with conditioner, and fold. this will keep them blond as I assume you want to keep them. Between the foils you will need to use a 5 or 6 ash based color, this will neutralize the orange color you have now. Use 10 vol developer or even 5 vol if your hair is in bad shape.leave on about 10 to 15 mins, rinse off a piece to check color progression, when it's a neutral brown you will need to rinse. I wouldn't leave it on more than 30 mins or you could end up ashy.
