Install fresh batteries, or if you already did that or it's new, select a different code.
Change jumper settings - probably a neighbor has same doorbell
see
http://www.fixya.com/support/t4787488-jumper_settings_for_sl_6151_rx_a
SOURCE: Wireless doorbell rings by itself
Doorbell button is sticking or slightly pressed in. Check to see if cover is installed correctly. It may be on on one side.
SOURCE: I have a wireless SL-6151-RX-A door chime and it does not ring
Check that the dipswitches on the button and the reciever doorbell unit match. Also verify that your battery is not installed the wrong way.
Testimonial: "Yes you were right the battery was dead thanks Henri"
SOURCE: My Desa Specialty doorbell doesn't ring..I have
Batteries are located in the doorbell push button case in the back. Slide open a compartment to reveal the batteries.
SOURCE: JUMPER SETTINGS FOR SL-6151-RX-A
I just solved a similar problem with mine. I found a PDF of the instructions for changing the frequency and the tone: http://heath-zenith.hcents.com/data/manuals/598-1034-02.pdf
