Question about Samsung Televison & Video
Samsung lcd tv comes on for a few thwn pitcher gos black but still has sound
    Sergeant:
  • Samsung Expert
  • 430 Answers
In most of the case, the problem is defective LED back lights strips.
Posted on Feb 08, 2019
2 Suggested Answers
freetek
  • 5569 Answers
SOURCE: 42" lg lcd tv pitcher flickers then gos black
Since the audio is still working, the main power supply probably
wasn't at fault and you may be looking at more research and possibly
more expense.
The problem is very likely on the largest board or with a failing
circuit that is part of the display.
You may be able to isolate it by using 'freeze spray' which you can
buy anywhere electronic parts are sold.
I suggest more than one can of it; ~ $7-8/can.
You will need to have the guts exposed and the set turned on.
Look around the edge of the display itself for chips (ICs) and give
any you see one brief shot of the spray, wait for ~1 minute for it to
'soak' and then move on to the next one.
If the video comes back, even if only briefly, repeat the cool-down
until you are confident to have found the right one.
If you can isolate it, you still have a problem.
If the sick IC appears to be 'glued' (with solder) onto instead of
through the board, you may not be able to replace it successfully.
If you can see that it has pins going through the board, these can be
replaced by anyone with a professional soldering tool and a steady
hand.
Remember, the problem can be on a board that is only connected to the
display panel but if on the panel itself, you may not be able to buy a
replacement for less money than a new set would cost.
Posted on Nov 10, 2011
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Rca pitcher gos off and sound stays onl lite blinks 5 times twice thep pic comes on for a few min and repeats
This is surely an error code generated by TV computer and your only way to see what it is is get the maintenance manual (maybe from the TVs website). Probably not worth fixing if you need to take it to the shop. I just bought a 40" LED TV for $199 and the minimum diagnostic is often quite high. Worse, the repairs are getting much more expensive due to manufactures not wanting to stock small repair parts. So even if it is a small cheap part broke, they only can replace large expensive modules (if at all).
Oct 21, 2015 | RCA Televison & Video
Screen GO'S Black then the sound & tv go's off
check the door switch for the bulb, if it is not contacting with the switch the tv will turn off. it somtimes dont catch the switch when you put the door back on.
Mar 31, 2014 | DSMiller Inc Samsung Rpt50v24dx/sms 150...
more expense.
hand.
Nov 09, 2011 | LG 42LC2D 42 in. LCD HDTV
Samsung 27" lcd tv picture goes black, still have
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!(*&^%
Mar 19, 2011 | Samsung LN-S2738D 27 in. HDTV LCD...
Screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Jun 20, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
No pitcher
The power supply is not providing enough voltage to the back inverter board due to leaky or dry capacitors in the power supply.
The power supply will need to be replace or repair to restore the LCD functionality.
Sep 17, 2008 | Astar LTV-3001 Television
Philips TV 27PT543S37A
ctgarden girl, my set does the EXACT same thing! I too wondered if a cold room was an issue. The set is only 4 years old, and I didn't have this problem in my old place where the room was a lot warmer.
Can someone please help?!?!?!?
Jul 08, 2008 | Televison & Video
Samsung Projection TV
You need to take out the DMD bord and open it up then remove the DLP Chip very carefully and blow out under the chip and all the components in the box with dry air something with a dryer on it then reassemble the chip on to the bord and make sure that the three screws that holds the mount that houses the chip are snug then you will need to put the Bord back in and have someone Else watch the pitcher so you can center the pitcher. This happened to me with my samsung tv and ran across this in sum service notes for this problem. Hope this helps
Dec 22, 2007 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
