Question about The Audio Players & Recorders
Sensor 1200 w how to set the clock?
I need to reset the clock and can not figure out how to do it.
How do I reset the clock on my microwave??
Press stop or clear, then press clock, set the time of day. Then press clock again. I believe.
Oct 15, 2017 | Panasonic Microwave Ovens
How do I reset the time on my HHScott Inc Atomic Clock ?
An atomic clock should set or reset automatically. That's what an atomic clock does. Right now my clock reads 1:35 and the computer read 1:37. Go figure : - )
Nov 21, 2016 | Home
Setting clock for cascade CEO91DM
first reset the microwave after set the clock
Jan 28, 2014 | Dacor 2 cu ft 1200-Watt Countertop...
Alarm clock time keeps resetting
Download the manual here: http://www.manualslib.com/manual/1056350/Ge-7-4809.html
Dec 08, 2013 | GE 7-4809 Clock Radio
I need a manual for a Vextra CD/Clock Radio VX715. I can not figure out how to set the clock radio alarm
The settings on this clock were difficult to figure out even with the manual. I made a lot of notes in the manual to help myself each time I had to reset the clock and CD Alarm. See Attached .pdf.
Nov 13, 2010 | Audio Players & Recorders
I have a chefmate digital kitchen scale and I do not know how to reset the clock.
I have the same problem. The only way I can figure out how to reset the clock is to take out the batteries and put them back in at 11:59 pm or midnight. Replacing batteries reset the clock to 12:00 am. So if you do it at midnight, you'll end up with the right time. But for the life of me, I cannot figure out how to actually set the clock using the availble buttons.
Apr 13, 2009 | Health & Beauty
Reset cd clock radio? (manual missing)
Make sure the clock is in standby mode, as opposed to playback mode. Press time set button — the clock digits will blink. If they don't, you're in playback mode. Press the hour button to adjust the hour. Press the minute button to adjust the minute. Press time set button to confirm the time.
Sep 30, 2008 | TruTech Clock Radio
Temperature sensor
I have this clock and just finished getting it all working again. At first I kept messing around with the AAA batteries in the remote unit, finally realized there were AA batts in the back of the main clock/display unit. Replaced those, pressed the reset button next to the battery compartment. Pressed the reset button on the remote unit (it's under the back lid next to the AAA battery compartment). Little red light on the remote unit started flashing and remote temp showed on the main display. Then you have to wait for atomic time to reset itself or set the time and other display options manually - I kept messing around with the various buttons until I figured out how to do this (atomic time never reset) - start by holding down the smaller "AL" button on the top next to the big snooze/light button, use top two side buttons for up/down, use the AL button to go to next setting.
Aug 15, 2008 | Honeywell RC182WR Atomic Alarm Clock - Red
Setting the Time
First, turn the Function Knob (bottom-left of the Control Panel) to “Clock”.
Hours: Press and hold the “HR” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press(pulse) the button to advance one digit at a time.
Note: When the number passes 12, the PM light will be displayed on the LCD.
Minutes: Press and hold the “MIN” button to go through the numbers quickly. When the number displayed approaches the desired setting, release and press (pulse) the button to advance one digit at a time.
To finish setting time, turn the Function to any setting other than "Clock", or simply wait until the numbers stop blinking.
Jul 26, 2008 | Cuisinart DCC-1200 Coffee Maker
Soundesign 316G Jukebox Alarm Clock-can't set alarm
Press the alarm reset ( on/off ) for a few seconds.
Same as you do to set the time
Feb 13, 2008 | Novelty Simpson Jukebox Alarm Clock Radio...
24 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
meowwl
Level 1 Expert
D. E. Hev
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
