Memorex Ultra PortableTravel Speaker MA3122 made for IPOD - IPhone 4S, IPhone 3GS, IPhone 3G
SOURCE: ipod adapter clear
Sorry, it 'WILL NOT' charge a 4G Nano on this Dock no matter which adapter you use!!
Clear Adapters have small numbers on them which relate to different iPods - A reference sheet relating to these numbers is enclosed with the Adapter Pack!
SOURCE: memorex travel speaker with ipod
Hold the "Time Set" button until the time starts flashing, then press the "play/pause" button so that only the hour is flashing. Use the ">>" and "<<" buttons to set the desired hour. Once the hour is set, press the "play/pause" button again so that the minute is flashing. Again, use the ">>" and "<<" buttons to set the desired time.
To change to military time from am/pm, hold the "Time Set" button until the time starts flashing, then press the ">>" button. In order to revert back to am/pm, hold the "Time Set" button until the time starts flashing (if it is not already flashing) and then press the "<<" button.
SOURCE: suddenly I can not charge
When pluged into the car liter outlet does the moniter light come on? 1 check the fuse by unsrewing the pin tip of the plug, look to see if the fuse is blown, you may need a OHM merter if you can't see if the wire is still in one piece. 2 check the cigar lighter in the vehical with another plug or lighter to see if it works if not then find whitch fuse is blown in the fuse box of the vehicle, and replace either or both.
SOURCE: iphone 3gs works properly only
Try the master reset function to solve this problem,here is how you go about it;
Press and hold the power and menu button simultaneously for at least 15secs,then release after the phone restarts automatically.
