What does the yellow light on the rim mean? - Audio Players & Recorders
  • 4 Answers
Might mean Low tire?
Posted on Jan 23, 2019
SOURCE:
Hi my name is Mike I have a 2002 x5 and in the dash board there was 4 little green lights on on bottom right now I got one red one and one yellow one what does it mean thx lots
Hi Mike. The lights are the service maintenance lights. When an oil service or inspection service is performed the lights should be reset to all green. Over time the lights will go from all green lights and disappear until a yellow light comes on. The yellow means the next service is due. The red means over due.
Feb 10, 2017 | 2002 BMW X5
2011 terios . Yellow spanner light comes on. What does that mean
The yellow spanner light indicates a service is due
Jul 09, 2015 | 2010 Daihatsu Terios 1.5
I put new rims on my 2010 dodge avenger and now my yellow (!) keeps flashing. my tires are not low. how can i fix this
your car had tpms tire pressure monitoring system in each rim you previously had on. they did not get put on the new rims so your car thinks your tire pressure is at zero. so it freaking out. you need to get those sensors on the new rims and reset. that will solve your problem
Mar 06, 2013 | 2010 Dodge Avenger SXT
I can't figure out what the yellow light means
Diane, what exact model of Samsung printer do you have and where are you seeing the Yellow light and under what circumstances?Does the printer work correctly or do you have problems with it?
Dec 26, 2011 | Samsung ML Office Equipment & Supplies
The light is on yellowe
Hello Qutey Babe, Hi.... the yellow light means there is no signal from the CPU. check your CPU.
Blue means normal, there is signal coming from CPU Yellow (orange usually). means no activity on the CPU,
Dec 06, 2010 | Acer AL1916W 19" LCD Monitor
I installed a set of 225 60 r 17 winter tires on my 2008 sebring and now have a tire with an exclamation mark light on the instument cluster, What does this mean the all season tires were 215 60 r 17 and i...
ignore this silly light ,just put a bit of black tape over it ,the tyre pressure sensors are inside the valves on the original rims ,black tape will cure it
Nov 25, 2010 | 2008 Chrysler Sebring
Hi i have a 8220 and red light is blinking on charging. I have checked very possible thing even the charger but cant get around pls help! thanks
Please don't worry this is caused because of various reasons.The lights explains what could be the problem
Orange and Yellow lights mean no defects in the mobile.Orange is phone battery is very low.Yellow is for boot up..
Red light means-You have power management problem.
You have to understand why it is being caused..
1)Due to dead battery.The phone will charge but you phone battery will not get charged it acts like it is getting charged.Behind the scene it cant store the charge.
2)Due to charger is not working properly no charge in the battery.
So you have replace this accordingly..
Please try this some time phone booting may be stopped,
This is not a solution when the battery is dead or fully down....
Sometimes The boot cycle of the phone is stopped.You have to start it.Remove the battery and place it again and press the red 'end' button continuously until the red light flashing stays on.Press green button' call' button and hold the red button...Now press these two buttons alternatively until you see hour glass symbol.Now when you see hour glass wait and see the phone booting....
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
2002 Ford Taurus has a flashing explanation point?
If you have tire pressur monitors on your rims, it may be that they detected a problem, or the monitoring system is defective.
Feb 26, 2009 | 2002 Ford Taurus
What does the yellow light mean?
when the light changes to yellow it is just adjusting to the newly added water. If you let it run the light should turn back to green. I think the light is only indicative of water level. I've had this humidifier for over a year and only gotten a yellow light once. It turned green after some of the water in the basin drained. Hope this helps
Dec 13, 2008 | Crane Cow Humidifier
I need to know what a yellow (!) followed by three low beeps.
This is a tire pressure monitoring light. Check your air pressure.
Nov 17, 2008 | 2004 Mazda RX-8
24 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
