Sony 55-inch
SOURCE: 55 inch projection tv
BUSTY35,
Here is your screen info = protector...PS5501....$155.00
Lenticular = 23430819....NLA Fresnel..23430635...$135.00
...........................................T.
SOURCE: tv screen is cracked
try www.tvscreenprotectors.com
they help with finding discontinued tv screens
SOURCE: 2005 sony 55'' sony wega. a very thin blue line is
Are you using a cable or sat box. If so then you are selecting channel using the tuner in the box and sending a constant signal to the TV eithir on one channel of the tv tuner or one of the other input of the tv. If this is the case I would suspect the box and not the tv because you say it is only on some channels.. If you are using the tuner in the tv with cable or antenna directly in I would say the main board that has the tuner on it needs replaced. Without a specific model number thats the best I can do. Hope this helps.
Testimonial: "thank you i will change the dvr from cable and see."
SOURCE: We just got a 55 inch LG LED TV. How do we set it
Easiset way is to use the HDMI Connecters and ports from the Direct TV box to the HDMI port on the TV...then set the imput source to the HDMI port that you used on the back of the TV.
SOURCE: I just brought my tv in 3 days ago 55 inch led 240
THE VIZIO XVT553SV has a know problem of random power cycles and random shut offs.
It is recommended you call Vizio Technical Support for a proper and permanent solution.
Toll-Free: 877.698.4946 (877 MY VIZIO) Technical Support
if you don't get proper assistance at that number call the Executive Office
at Phone: 949.428.2525
Unplug the power cord of the receiver box for 10 seconds and then plug it back.
