Question about Whirlpool Freezers
Model EVL201NXRQ05 serial eww4020663 WHIRLPOOL UPRIGHT FREEZER - Freezer which is having ice freeze on the bottom of the freezer. What can I do?
    Top Expert:
  • Whirlpool Master
  • 6,289 Answers
Defrost drain is clogged.
Posted on Jan 24, 2019
    Sergeant:
  • 170 Answers
The defrost water from the melted frost (ice) collects in the bottom of the freezer. If there is no plugged up drain, then you must remove the water manually with a sponge and bucket after a defrost cycle.
SOURCE:
HVACRH20
  • 237 Answers
SOURCE: Whirlpool Freezer Model #EV150NXENOO
This one sounds like the defrost timer is not working and you are not getting a defrost cycle every 6-8 hours (or when needed). Another issue could be that air (moisture) is getting in from a leaky door seal, etc. and causing the freeze up. If you have a sealed system problem where the cooling coils are not uniformly frosted up then the defrost thermostat will not "know" there is an ice condition and therefore not go into defrost mode (same issue if the defrost t-stat is bad). After you have ALL the ice out of the unit it would be a good idea to take the interior rear cover off so you can view the coils. Start the freezer back up and watch over the next 1/2 hour or so to see that the entire coil is frosting up uniformly. If it isn't you may have a plugged system, a leak causing low refrigerant, etc. If over time the coils look uniformly frosted up you may have a defective defrost heating element itself (no heat, no defrost sort of thing). The defrost elements can be checked with a multimeter for continuity if you know how to do that sort of thing. It's hard to know a person's ability by these forums or if they can tackle certain test procedures.
Posted on Nov 13, 2006
  • 124 Answers
SOURCE: Upright Freezer not freezing,
looks like low on freon. that causes freeze up. oddly enough they freeze up when charge is low , just the opposite of what you think they would do. you have a freon leak unfortunately. probably not accessible, and therefore not repairable. i would suggest, cut your losses and buy new. unfortunately for me and all other srevice techs, the days of affordable repair are over, you can now replace cheaper than i can fix and have a warranty and its new... good luck
Posted on Nov 27, 2008
  • 25 Answers
SOURCE: Kenmore upright freezer Model # C675-287140J
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Posted on Mar 08, 2009
woodchuck789
  • 4070 Answers
SOURCE: Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Posted on Oct 13, 2009
SOURCE: My Upright freezer Hotpoint Product code 755703
My FZA 84 regularly has to be defrosted as it overheats.We do this by taking off the back panel - as shown by the Hotpoint service man here in Dublin. We use lukewarm water or a hairdryer to defrost the buildup of ice. Why its building up is anyones guess.The repairman suggested we might be leaving the door open but we certainly aren't. I'm very disappointed with the product and I wouldn't be purchasing Hotpoint again.
Posted on Jun 09, 2010
Drain tube opening clogs with ice inside freezer.
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com and provide your full name, phone number, address and the model and serial number for your freezer.
Apr 01, 2017 | Whirlpool Freezers
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have a Whirlpool Model EV 200N Upright Freezer which is having ice freeze on the bottom of the freezer. What can I do?
If there is frost forming at the bottom to the door, your door gasket is leaking at that location. You may be able to relax gasket back in place with hair dryer, be carefull you can melt gasket. If it is sheets of ice, your defrost drain may be frozen
Aug 28, 2010 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
My upright freezer has a small amount of water inside that freezes, creating an ice slide in bottom.
look at the bottom of your freezer, you will find a small hole or opening, it is a drain exit point of your defrosted water, try to clean it, maybe there is a small object bocking up the way or the hose all away down
Nov 06, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Whirlpoll Freezer model EV190NXWN00 not freezing
it sound like is not defrosting if is upright freezer. open the back wall jerry if that evaporator is full of ice then it has cut off all the air flow and in return that is why is not freezingif you know how to use the voltage meter you might need to check continuity on the heater if it check ok then repl the bimetal part# 4387499 and timer 482493 when repl time follow the wiring schamatics realy carful look for the right clor harness in the instructions and then just let it defrost or use the hair dryer
Oct 18, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezers Logo
87 people viewed this question
Top Whirlpool Freezers Experts
AJMAL KHAN
Spencer Field
Spencer Field
Level 1 Expert
Steve Allison
Steve Allison
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
