Question about Cajun Grilling
My cajun smoker hums when I plug it in but the power panel will not light up.
3 Suggested Answers
SOURCE:
  • 127 Answers
SOURCE: cajun electric smoker code ErrF. Was working but
Possibly a control unit malfunction.
First try a full reset. Turn off and unplug the smoker from the outlet. Wait a minute or 2 to allow the controller to power down completely. Plug the smoker back in and turn on.
If you get the same error message it is likely that the control unit needs to be replaced. Part #990050048.
You can contact Masterbuilt directly at 1-800-489-1581
Posted on Jan 01, 2011
wa6igj
  • 743 Answers
SOURCE: I have a cajun injector xl double door electric smoker and I need the wood chip tray does anyone have any suggestions where to get one
TRY hunting these guys (and gals)...
Electric Smoker Replacement Parts elements rack tray pan
Anthony
Posted on Jul 08, 2018
I need part for Cajun Injector smoker
What's the model number and what's the part you need? If you're not sure what the part's called, check here:
https://www.manualslib.com/manual/733139/Cajun-Injector-Electric-Smoker.html?page=4
Feb 28, 2018 | Cajun Grilling
I have a double glass door cajun injector electric smoker. I need to replace the heating element located under wood chip pan.
online search using make and model or if have the owners manual call their customer service number
Nov 13, 2017 | Cajun Grilling
Where can i buy replacement elements for the cajun injector smoker
Sorry we do not have parts locator services here.
Sep 04, 2017 | Cajun Grilling
Cajun injector electric smoker stopped working
Check for power at your outlet; a tripped GFI or a tripped breaker in your panel box may be the cause if the outlet is dead. If the outlet is good then you know it is the electric smoker.
Nov 27, 2014 | Cajun Injector Double-Door Xl Electric...
Thermostat is stuck on 387 degrees. How can I fix it?
I had the same problem. Readout showed 330 degrees, but it should have been 60. Saw all the bad reviews on this product after I started to research this problem, so I figured I would try to fix it. I drilled all the rivots out of the back panel. There are 2 thermocouples, 1 for the meat probe and 1 for measuring the temp inside the smoker. Both thermocouples have connectors in about the center of the smoker. I cut the wire on both sides of this thermocouple and spliced them together without the connector. Works fine now.
Jan 11, 2014 | Cajun Injector 01939 Electric Smoker
Electric smoker won't heat up
yeah you could retro fit it and hope for the best..just dont leave it unattended in use..
Jan 11, 2014 | Bruce Foods Cajun Injector Creole Garlic...
Sino mahal ko
Awesome little grill
Thanks for sharing
Cajun Grill Video Demo
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 28, 2010 | Cajun Camo PGI-200 Grill
I need a replacement heating element for a Cajun injector electric smoker
Hi, replacing heating elements can be found at amazon, click here and take a look: Save Time Money and Energy with Induction Cooking. I hope this helped you. Have a nice day
Oct 21, 2010 | Bruce Foods Cajun Injector Creole Garlic...
Grilling Logo
76 people viewed this question
Top Cajun Grilling Experts
Craig Buck
Marvin
Marvin
john h
Are you a Cajun Grilling Expert? Answer questions, earn points and help others
