Question about Samsung Dryers
My Samsung dryer will only power on if it is unplugged and plugged back in .. also , we can not change the settings it just stays on normal
    Top Expert:
  • Samsung Master
  • 61,875 Answers
PERHAPS YOU NEED TO CALL A REPAIR SERVICE LOCALLY AND GET IT TESTED ,MOST LIKELY IT NEEDS A NEW CONTROL BOARD
Posted on Jan 24, 2019
SOURCE:
Have a Samsung 65” led tv. Model # UN65H6203BF. LED back light blinks and red status light blinks when power plugged in. Changed Power Supply(used but good), no Change, all still blinks. Can unplug main...
You may have a back lights problem.
To test the back lights, you need to disconnect the cable between the main power supply & the main board, apply the AC power to the power supply, if the back lights are not light up, or blinks, the back light are defective.
Sep 12, 2018 | Samsung Televison & Video
Bought new Samsung dryer and won't turn on - wired incorrectly on first attempt, did we short the dyer?
Hello
Just a hitch, but maybe the fuse is bust and needs to be replaced.
ilona
Aug 02, 2017 | Samsung Dryers
My Samsung dryer DV218AEWXAA is not coming on. There are no lights on the dryer. We recently had the heating element replaced. What could be wrong with it?
Is ther power at the outlet? If yes, try unplugging dryer and plugging it back in. If that doesn't work, try unplugging and plugging back in while holding down power button. Good luck.
Mar 05, 2015 | Samsung Dryers
Is there a reset on a Samsung dryer model number DV220AEW/XAA
normally if u unplug it for a couple minutes then plug back in , may reset . also try putting it on the on position then open and close the lid slightly 6 times withing 12 seconds, it may reset it
Jun 03, 2014 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Gateway NV52 won't wake up.
Is it clean? fan and vents? Unplug, remove battery, leave battery out, plug in, reboot. If that fails, Re Boot and try a System restore/recovery to a date before this issue. OR, Boot to Safe Mode, use this procedure to select Normal Boot: http://www.netsquirrel.com/msconfig/msconfig_win7.html When/If you get a Normal Boot, Open Control Panel, Power Options, select High Performance, select Change Plan settings, set plugged in both to Never, set advanced setting to your preference. Use this procedure: http://windows.about.com/od/customizingwindows/ss/set_power_options_all.htm Always shut down and unplug your laptop when not in use, remove battery when you use on AC, your Laptop/components will last longer, and will not be subject to possible power surge damage and the battery, IF it malfunctions will not cause a fire hazard.
Mar 01, 2013 | Gateway NV5214u Notebook
My dryer will beep most of the time and then I've noticed if it beeps it won't dry. It will dry some of the time and then it won't . What do I need to do. The dryer is only about 2 years old if that.
Turn off the power and unplug the cable, wait 1 min. and plug it back inn, turn the power on and it will go back to normal setting,
Regards, Jenplas
Jan 04, 2013 | Dryers
My Samsung hcn4226w won't stay on.
There are many protective circuits inside the set that will shut it down if a problem is detected. It sounds like there are intermittant detections of problems and the "restart" temporarily clears the problem. If the unit is no longer under warranty, open up the back with the set unplugged and try reseating all of the boards and connectors. The trip may have jared a few things loose. Update this with the results.
Thanks,
Dan
Aug 20, 2009 | Samsung HCN4226W 42" Rear Projection...
Dryers Logo
41 people viewed this question
Top Samsung Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Mike
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
