Question about Hampton Bay Dryers
There is no blue wire in my Hampton bay fan - how do I control the lights with the remote?
23629-300 Fan Only a black and white wire present - lots of electronics in the housing - does that mean that this is the remote receiver?
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 103 Answers
Posted on Feb 10, 2019
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
  • 159 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
SOURCE: Hampton bay ceiling fan with built-in remote receiver
In case someone else stumbles upon this:
I replaced the remote receiver on one of these fans. jb is right just the top housing that touches the ceiling needs to be removed. Twist it counter clockwise and pull down. You'll see all the wires and the remote receiver. It might not seem like much room to work with, but you can remove the wires and slide the receiver out sideways to replace it or if you can't see the dip switches. Too bad Home Depot is too cheap to even provide instructions when they send you the replacement remove receiver.
Posted on Jan 24, 2010
  • 736 Answers
SOURCE: I have three house wires supplied- white, red, and
make sure power is off before working on the fan wiring ..(trip circuit breaker)
here is what the house wires are
1. black is hot (power) all the time .. its normally connected to the black wire of the fans speed control switch .. that is normally operated by a pull chain ..
2. red is the same power as black except it comes from a wall switch .. this would be connected to the blue wire in the fan (that goes to its light) .. that will allow you to turn the light on an off from the wall switch ..
3. white is neutral .. it connects to both white wires inside the fan .. one goes to the fan the other goes to the light. .. if there is more than one light bulb then there will be more white wires .. hook them all together and to the white house wiring ..
4 then there is safety ground .. usually green or bare copper ... that is connnected to either a green wire inside the fan or bolted to the metal of the fan (often a green bolt is provided) .. the green wire is not required for the fan to run but is required as a safety to make sure no one gets shocked on the fans metal parts ..
after you wire the fan ..then turn on the wall switch .. if the light doesnt light then pull its pull chain until it does .. you can then tie up or remove that chain to prevent anyone from changing that position since you can now control the light from the wall switch you dont need that chain anymore .. the fan should come on slow med and high then off .. each time you pull its chain ..
Posted on Jun 07, 2010
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
Trying to rewire a hampton bay light fan. I have
Try switching the red and white wires
But it should be working if the light is.
Make sure all the wires to the remote are connected good. You may just have defective remote.
Nov 29, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay ceiling fan remote control
i have a problem with remote ceailing fan and light i tried push on light key - dim light low to high working but fan isnt working hi to low. i checked the supply wire red, white and black so i have a installing receiver and receiver have red receiver wire to black supply wire, white receiver wire to white supply wire , but what i do with red supply wire to QQQQ
Jan 25, 2009 | Universal Remote Control Hampton Bay...
Wall switches do not control fan
Some fans will not operate without the remote, however, I'm not sure if the Hampton Bay brand is one of these or not. Below is how you will bypass the remote if the fan will operate without the remote.
You can try disconnecting the receiver in the canopy of the van (the cover that fits snug to the ceiling) once you have shut off the power source remove the canopy and find the remote receiver.
Most likely it will be a rectangular box with white, black, and blue or red wires attached. Disconnect all wires from the receiver and lay it to the side.
Now reconnect the wires directly to the fan, white to white, black to black, if you have a red wire (or a second black wire) in the ceiling box connect it to the blue wire from the fan.
If you do not have a red wire (or second black wire) in the ceiling box, connect the black and blue wire from the fan to the single black wire in the ceiling box. This method will require you to pull the chain to operate the fan separately.
Dec 12, 2008 | Hampton Bay 52 In. White Redington...
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Problem with Hampton Bay 54 In. Flemish Pewter Ceiling Fan With Heater
did you check the circuit breaker to see if its tripped?im assuming the voltage rating of the wires your decribing are 110 volts and the fan likewise.the white wire could possibly be a neutral wire,meaning you should hook up the red and black wire.let me know
Jul 30, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Dryers Logo
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Gene Pitts
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
