Question about Maytag Refrigerators
My Maytag ice maker in the left door will not operate unless I press the top of the left door
SOURCE:
SOURCE: Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
Posted on Sep 01, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
mikedurland
  • 481 Answers
SOURCE: Maytag Refrigerator Ice Maker
  • first make sure the metal arm to the right of it is lowered, this turns the icemaker on.
  • then you can check the water supply to make sure it is turned on, sometimes when houses are vacant they turn the water off as a precaution. the valve may be behind the refrigerator or under the sink in the kitchen.
  • then...
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 04, 2008
woodchuck789
  • 4070 Answers
SOURCE: Maytag MSD2754GR - Ice Maker quit working.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Aug 29, 2009
Testimonial: "Good trouble shooting tips...will give them a try and see how they go, THANKS!"
  • 19 Answers
SOURCE: The ice and/or water won't stop coming out the
It sounds like the actuator for your dispenser switch is sticking. To fix it you will need to get inside the dispenser housing, which involves removing the decorative front panel on the dispenser.
It's kinda tricky to get this thing apart, and it's even harder to get it put back together if you've never done it. I'd recommend calling a repairman.
Posted on Sep 28, 2010
Maytag bottom freezer ice maker leaking water. It fills the tray in about one hour. How do I shut off the water supply or turn off the ice maker? I suspect the lever is not functioning properly.
The water line shut is usually behind the unit.Pull it out from wall. Just turn clockwise to shut the water off. Depending on your model you can turn the ice maker off by letting up the handle in the ice tray.That shuts it off from making ice.Newer models have a button on door that reads ice off.But if it's leaking water.Shut water off and left handle up or ice off at door. That way it's not trying to make ice.
Jun 29, 2018 | Maytag Refrigerators
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
recommended."
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
Attn:CAIR
Center
P.O. Box 2370
Cleveland,TN 37320-2370
U.S.
1-800-688-9900
CANADA
1-800-688-2002
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
Feb 24, 2017 | Refrigerators
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Ice maker won't work
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
When the light switch in the freezer goes out (by me holding the the switch in or by closing the door) there is a noise that comes from the ice maker. Turn the light on, it stops. Any ideas? The noise is a...
The door switch is designed to turn off the dispenser control when the door is open and the light comes on. Pressing the switch with the door open turns on the dispenser controls and the sounds of relays and solenoid coils would be normal unless it is affecting your dispenser or ice maker. Thanks, Sea Breeze
Sep 30, 2009 | Maytag MSD2651 HE Side by Side...
Ice maker in Maytag French Door not working
replace the ice maker if the reset button has not done any good
Sep 16, 2009 | Maytag 25 Cu. Ft. French Door Bottom...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
I need the wiring diagram for an ice maker for the Maytag Refrigerator # PBB2255GEQ
Bring your model number to my site and enter the model number in Model search. The search will take you to your model and on left side of screen scroll down to wiring diagrams. Click it and you will get the complete wiring diagram. At top right you will see the ice maker. Hope this helps, Thanks, Sea Breeze
Click below
http://servicepartstec.blogspot.com/
Mar 19, 2009 | Maytag MFI2568AE Side by Side French Door...
Water/ice dispenser doesn't work
I had the same problem - I got it out of it by pressing a specific sequence of buttons - maybe holding one or more down when pressing another - Dummy me I didn't write it down. I am having the same problem now. I called Maytag - the local guy said he'd call back. I 'll keep watching here
Jun 26, 2008 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
46 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
