SOURCE: Car stereo
Sorry to burst your bubble, but you CAN'T rebuild the coil, for a multitude of reasons. It's THEORRETICALLY possible, but pragmatically IMpossible. Trust me, I know. Yes, your speaker is glued together (with VERY strong glues. When you dismantle a speaker you have to replace many parts including the surround and spider...). With that said.... There ARE shops that can repair speakers (and, no, they generally don't handwind coils...), but they are far and few and pretty expensive. A base model sub like that would't be economical to repair. I don't know where you're at, but the only one I know of is "The Circuit Shop" in Grand Rapids, MI. feel free to google them and call for a quote.
SOURCE: TROUBLE WIREING SPEAKERS
Lots of info here; http://www.the12volt.com/Default.asp? You have to register, but its free. Best of Luck.
SOURCE: 10 inch cvr kickers
Option 1 (series/parallel) = 1 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono
SOURCE: how do you wire four 12 inch kicker cvr dual voice
Hello brysonford00,
The wiring configuration depends on what final impedance you want the amp to see. If the subs are 4ohm DVC's, you can wire them to present a 2ohm impedance or an 8ohm impedance. The diagrams are here. If your subs are 2ohm DVC's, the wiring is the same. The impedances will be 1ohm and 4ohms.
Hope this helps.
