It sounds like there may be a startup error, try taking it back to the place you purchased it from,also you could try taking it to an electronics repair shop,, if its a malfunction you shud have a warrenty and they shud be able to replace it for you,,also you can purchase the same exact model here or find a new one here>>>www.discountbargainprices.com
SOURCE: Macbook - screen white/blank after turning on
Sounds like it could be a corrupted OS; have you tried forcing it to start up with the OS disk, holding down the 'C' key? That's the first place to start...
If it won't start up like that, you probably have a hardware problem. (You can get excellent troubleshooting guidance at: http://www.ifixit.com/Guide/Mac/ ) depending on your level of geekness, and assuming the warranty is expired?
Good luck
dennismacfreak
SOURCE: iphone won't boot past Apple logo after installing
Sometimes the iPhone can lockup and stop working or just show the
Apple symbol and not do anything else. But panic not, normally an app
has caused the phone to crash and it needs to be restarted.
Here’s how you do it:
Sometimes just pressing and holding the home button for about 5 seconds, can help. But if not try this:
Press and hold the iPhone’s
Sleep/Wake button and the Home button for several seconds, or until you
see the apple logo on the screen.
If you still have no success with the reset the only other option is
to do a restore using iTunes. This will wipe you iPhone bust should get
wit working again.
SOURCE: Stuck on black and white Apple logo screen
Solution 1) Press Hold/Sleep & hold buttons at same time for 20 seconds, This may fix you problem.
If problem is still alive follow solution 2
Solution 2) Press Hold/Sleep & hold buttons at same time for 10 sec. & then leave only Hold/Sleep button keep home button pressed & connect you ipod to PC, That means you have to bring your ipod in DFU mode (Recovery mode) Check out this video for getting ipod touch in DFU mode http://www.youtube.com/watch?v=bITIiGswjFI
. itune must be run on PC.
It will ask you for restore. Accept Restore you ipod touch request by itune. Wait for few minutes while ipod being restored.
This process will solve your problem 100%. I have solved same problem for ipod touch. Follow this video http://www.youtube.com/watch?v=AQk4-krrNVk
Thanks.
If my solution help you please vote up me.
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
