Question about Garden
Where i find brake switch 445 JD tractor tractor quits when brake release but i cant find switch
    Champion:
  • 230 Answers
Won't be the brake switch it will be the seat switch
Posted on Jan 23, 2019
    Loyalty:
    Visited the website for 30 consecutive days.
  • Garden Master
  • 496 Answers
Left side frame under foot rest.
Suggest you first check the seat switch. Most deere riders you can start/run engine with brake set while not in seat. But operator must be in seat when brake is released. Your in the seat and it dies, so seat switch failure.
But here's instructions for brake switch.
BRAKE SWITCH TEST AND
ADJUSTMENT
Reason:
To make sure the brake switch has continuity when the
brake pedal is depressed.
Equipment:
• Ohmmeter
Connections:
1. Turn key switch off.
2. Depress brake pedal and engage park brake lock.
NOTE: Brake switch is located on left side of frame
under footrest.
3. Remove footrest.
4. Disconnect brake switch connector.
Procedure:
1. Check continuity across terminals (A). Check
continuity across terminals (B).
NOTE: Be sure actuator (C) contacts switch plunger
(plunger depressed) and not switch body.
2. Release park brake pedal.
3. Check continuity across terminals. Be sure actuator
does not contact switch plunger (plunger
released).
  • 37 Answers
SOURCE: mower dies when i try to engage blade
Hi, what you wrote is exactly what's is suppose to do. what is it about the mower that's not doing?
Posted on Nov 23, 2008
  • 376 Answers
SOURCE: Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
Posted on May 26, 2009
  • 86 Answers
SOURCE: how to release brake band when cover is removed on model 445 ?
HI. I HAVE USED THEM SAWS FOR 25 YEARS. WELL IT SOUNDS LIKE THE BRAKE IS INGAGED IF NOT YOU WELL HAVE TO LOSEN THE BRAKE OFF UNTIL IT WILL GO ON.WATCH OUT FOR DIRT IN BACK OF BAND. LET ME KNOW.
Posted on Aug 13, 2009
bbreton
  • 437 Answers
SOURCE: tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Posted on Sep 28, 2009
mickey813
  • 472 Answers
SOURCE: Tractor shuts off.
IF THE SEAT SWICH IS GOOD THAN THE BRAKE SWICH IS BAD
Posted on Oct 14, 2009
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
JD X595 4x4 mower - Starts OK, BUT, as soon as the brake is released, the motor cuts out.
I would try bypassing the seat switch and the brake switch. Do this one at a time to determine if the switch is bad. Also buy some Sta-bil fuel stabilizer and gel remover. I recommend this for any seasonal equipment. Often the engine is not getting enough fuel and will stall when the pto is engaged. Sta-bil often rectifies this problem.
Mar 06, 2015 | Light Garden
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
JD 445 no fire to the plugs and no fuel from the injector I tried another used A-1 coil checked all relays according to Tech manual all fuses good no broken wires
Check all safety interlocks. Any one will prevent the engine from starting.
1. Seat switch.
2. Brake interlock.
3. Blade interlock.
I don't know of any others. If any of these switches is OPEN the start circuit will not work.
Gary
Feb 07, 2011 | John Deere 22HP VTwin Hydrostatic 42"...
JD 855 the idle spring broke and th hydrostatic pedals would not return to their neturel position . before I new what had happene I pushed the reverse and the tractor lunged backward then I pushed the...
Yes there is a safety switch.And this safety switch has to be engaged.If its not engaged then the JD tractor will not start. On JD 855 the safty switch is located under the seat, There is a rod that must be depressed before engage Somehow that rod is bent or its not pressing the switch to the point that the seat would not fully engage the safty switch.In some cases the switch itself is faulty.It has to be checked . Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jul 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My JD L120 starter solenoid is not being activated. Besides the seat button interlock what esle my be inhibiting the starter?
The pto switch,park brake switch and the seat switch will cause the tractor to not turn over,also the ignition switch could be the problem,start with the brake switch,under the right floor pan.
Jun 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Craftsman garden tractor quits when brake released.
It sounds like your throttle cable is caught up with the brake pedal.
Oct 01, 2009 | Garden
Engine runs but keeps going up and down in RPM model JD 445
Have had to replace fuel line in tank MANY times do to it being split just above pump.Try doing a fuel pressure test on the return hose from throttle body,should be close to at least 40psi.
Sep 01, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
218 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
