Computers & Internet Logo
Dino Gjokaj Posted on Jan 23, 2019
M3 freezer stooped working no signal at all - Computers & Internet
How to wire a Sadelta M3 to a Cobra 29 LTD Classic
I believe to wire a Sadelta M3 microphone to a Cobra 29 LTD Classic CB radio:
The Sadelta M3 microphone has four wires: white, shield (bare wire), red, and black. The Cobra 29 LTD Classic CB radio's microphone jack also has four pins: Pin 1 (Audio), Pin 2 (Ground), Pin 3 (Transmit), and Pin 4 (Receive).
To wire the Sadelta M3 to the Cobra 29 LTD Classic, you need to connect each wire from the microphone to its corresponding pin on the microphone jack. The white wire carries the audio signal from the microphone's element to the radio, the shield wire provides a ground connection, the red wire activates the radio's transmit function when the microphone is keyed, and the black wire is used for receive audio.
Here are the specific steps to follow:
  1. Cut off the existing microphone plug on the Sadelta M3 microphone cord.
  2. Strip about 1/4 inch of insulation from each of the four wires in the Sadelta M3 microphone cord.
  3. Connect the wires to the pins on the microphone jack as follows:
  • White wire to Pin 1 (Audio)
  • Shield (bare wire) to Pin 2 (Ground)
  • Red wire to Pin 3 (Transmit)
  • Black wire to Pin 4 (Receive)
  1. Solder each wire to its corresponding pin on the microphone jack. You may want to use a multimeter to verify that each connection is solid and that there are no shorts or open circuits.
  2. Once you have soldered all the wires, test the microphone by speaking into it and checking that the radio's TX meter moves as you speak. Also, check that you can hear audio through the radio's speaker when receiving signals.
  3. If the microphone is working correctly, use heat shrink tubing or electrical tape to cover the soldered connections and provide strain relief for the wires.
Note that some microphones, including the Sadelta M3, may have additional features such as a built-in amplifier or power supply that require additional wiring.
GE model GSL25JFPD freezer stoope working. Can anyone help?
please make sure that temperature controls are set to the temperature that you want. Then, you'll want to double check that the power outlets that the freezer is plugged into still give out power by testing other appliances on them.
If the outlets don't work, then you would want to check the corresponding fuse in your fusebox because it might have switched off and just needs to be switched back.
Thank you.
Sir I have Konica minolta 850 I have problem Code is SC 23-02
Description
The speed error signal of the developing motor (M3) is checked. Since an error detection signal is detected a second after M3 turns ON, turn OFF M3 for a specified period of time. Then, an error detection signal is detected again a specified period of time after it is turned ON again.
Causes
Developing motor (M3) Printer control board (PRCB)
Steps to change water filter
the water filter is located in the grill/kickplate under the doors on the freezer side,the steps are,
open freezer door
stoop down
grasp the black handle and rotate it in a counterclockwise direction 90degrees
pull out filter
remove black cap and reinstall black cap on new filter
push filter into housing
rotate it 90 degrees in a clockwise direction
close freezer door
Gene
The freezer has stooped working it is the two door at top with freezer at bottom and ice and water not sure of model number.
check the back of your frige you will see the black roud metal under your frige that is the compressor check the overload of the compressor and also check the wiring diagram at the back of your frige see ther if thers an existing fuse in the wiring diagram.
1helpful
M3 Turboair Refrigerator does not cool
http://www.turboairinc.com/TB-Service/Service.html#SANDWICH
Try this web site. It has you M3 listed with manual but needs exacting model number to get right one.
good Luck - Hope this works for you. If not, let me know.
Jun 27, 2009 • Freezers
Nextar m3 and no signal
Hi.
You are facing this problem because of the US GPS Satellite because there's a sudden change with the code signal which leads to GPS signal anomalies.
Even though you've traded it. the problem is still there.
It's better to go with another brand or model.
As this problem cannot be fixed with this unit.
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
nm.nbydg
How do I turn off the freezer section on a fridge freezer?
Unfortunately you can't. Both the fridge and freezer sections are cooled by the same compressor. You can't just have one without the other!
Matt
Apr 16, 2008 • Freezers
Grand Canyon Tech
Grand Canyon Tech
