Question about Sony VAIO Computers & Internet
Where can i buy new bezel for sony vaio vgn-tt 17 4-000-662-02
This SONY logo frame of LED cover
    Top Expert:
  • Sony Master
  • 29,187 Answers
Try fleabay.
Posted on Jan 23, 2019
  • Farid Hacili
    Farid Hacili Feb 18, 2019
    Thank you for offer. But they support USA residents only... but i am not from USA.
silveradoman
  • 58 Answers
SOURCE: replace wireless card on sony vaio vgn-n130g
usually there are screws coming upward from the bottom to remove the keyboard,then you have to remove the palmrest which the touchpad is integrated into.
Posted on Apr 19, 2008
jonags3
  • 83 Answers
SOURCE: sony vaio VGN FJ290P password reset sony vaio VGN FJ290P
I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
Posted on Oct 11, 2008
  • 64 Answers
SOURCE: I HAVE A SONY VAIO VGN-FJ1S, BOOTS UP, THEN GOES SLOWLY WHITE/?
I actually did have a problem that was similar the screen would lighten up after a min or so and moving the screen fixed it. The actual cause of the problem was a loose chip on the circuit board of the LCD, i re soldered it to fix it, could also be a bad LCD cable.
Posted on Mar 06, 2009
SOURCE: fn key for laptop sony vaio vgn-s460p
the function keys doesnt need any extra driver.
but if you want to use tha additional features of function key like save, load, close and many more then you can get the software directly from official website of sony. alternativel you can download hotkeycontrol xp by which you can reconfigure you keyboard to add extra feature and options
Posted on Jul 06, 2009
  • 102 Answers
SOURCE: want to reset Sony VGN-NR160E/s Vaio NB to factory
Just power on your laptop and keep pressing F10 key. You will get one wizard to restore your laptop to factory settings.
iTechGuru
www.itechguru.in
Posted on Mar 29, 2010
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
How do i replace the backlight on my sony vgn-fj1s
It's much easier to just replace the screen than trying to replace the back light. Save yourself the trouble and buy a new screen on ebay.
May 02, 2012 | Computers & Internet
Vaio VGN-Ns135E fn key doesnt work
Visit the below page, select appropriate operating system and install the Sony Shared library and Sony Notebook Utilities.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNNS135E&SelectOS=28
Also ensure that the services are started for VAIO Event services.
Press Windows logo key + R key to open Run window.
Type "services.msc" without quotes.
Locate the VAIO Event services from list and set it to automatic and started.
May 28, 2011 | Sony VAIO VGN-NS135E/S Notebook PC
My "sony vaio vgn txn15p"
if your Sony is older then 3 yrs I urge you to get a new battery. Make it last longer by draining the battery and charging it up everyday. This gives it a work out and helps it not get lazy.
May 02, 2011 | Sony VAIO VGN-TXN15P/W Notebook
Screen Opening
There are clips that are holding it into place. Take a flathead screwdriver and put it in an area where the front bezel meets the back bezel. Twist the screwdriver around and it should loosen some of the clips, do this in a few places and then enough of the front bezel will be loose to where you can remove the front bezel to the screen.
Once you do that you can remove the screws from the left hand side and the right hand side. Then remove the cable from the back of the LCD and remove the plug from the inverter on the bottom of the screen.
You can now put the new screen in.
Apr 27, 2010 | Sony VAIO NS Series VGN-NS110E/S Notebook
How to remove the screen bezel
There are screws hidden behind round plactic covers on the bottom and sides of the bezel. Also they may have plastic clips and or double sided tape holding the bezel in place. Slip a thin blade between the screen and bezel and gently lift the bezel off, take care not to scratch the LCD screen.
Jul 31, 2009 | Sony VAIO VGN-T1XP/L Notebook
Fade screen....
SOUNDS LIKE BAD HARDRIVE after the logo screen and fade screen Then what happens ? does windows begin to load.
Jan 12, 2008 | Sony VAIO VGN-FJ270/B Notebook
Open Questions:
Rush to buy RS3gold runescape money with $10 cash coupon til Jan26 We're rs3 gold for sale going to have a strong group of people employed at FAU as soon as we complete the grant process, said Harbor Branch interim executive director Megan Davis. Also, we can involve graduate and undergraduate students, and in addition to the dig being very significant in terms of the types of artifacts, there's also a lot to learn from it in regards to the environment. Florida has been covered in water off and on over thousands of years, and this site shows us some of the changes that have taken place.. She carly405 might be on tomorrow. I am not in the clan, i am writing this becaus she carly405 is a good freind. Well that is all i have to say. Lord Drakan will then ask to speak to the player: choose any of the responses to continue with the quest and gain status with Lord Drakan. Drakan will then state that he knows that the player is a human; choose whether to spring the trap or call the retreat. Regardless of the choice made, a cutscene will occur, where Drakan learns of Safalaan's heritage, claims that the person who killed his father is amongst the group, and Safalaan activating his icyenic powers. It therefore behooves those who offer RuneScape as a file to make a Runescape Account Recovery Guide downloadable as well.RuneScape is the perfect game for the virtual community. It is open, transparent, and flexible. It offers the thrills and fantasy that many gamers enjoy. There will be high level rogues protecting these chests so that you need to bring some food and armour to keep these rogues off their back for getting some loot. The rejuvenation of the wilderness will be a big success for the old school runescape. Based on your help, Jagex believe that it will cause a lot more fun in 2014!. It was really fun to be a guide in massive dungeons on some of those quests. Knowledge was valuable, hehe. I want that experience again.. Pip is shocked, and stops taking money from him. Subsequently Pip and Herbert Pocket devise a plan for Magwitch to escape from England. Magwitch shares his past history with Pip, and reveals that the escaped convict whom he fought in the churchyard was Compeyson, the fraudster who had deserted Miss Havisham.. Smelt these into steel bars. Keep repeating this until all of your iron and coal ores are used up. You should now have 500 steel bars. For many years, free to play games like Dota 2 and RuneScape have enjoyed enormous success on the PC. However, it wasn until recently that console devs started to move in that direction in a substantial way. Developers of all sizes are now entering the fray, so we working hard to keep up to date with how well this business model works on Sony console. Great chance! Well-being is here.No hesitation to take part in RS3gold third around biggest promotion for OSRS Kebos Lowlands release II : Up to $10 coupon code KLS10 for you all buying RS3 gold,RS 2007 gold or other products on RS3gold.com with safe and fast delivery from Jan 19 to Jan 26.2019 .Notes: KLS3-$3 cash code If you order over $40+,$40 included; KLS5-$5 cash code If you order over $60+,$60 included; KLS10-$10 cash code If you order over $110+,$110 included. Meanwhile, you can use 8% off code SDM8for purchasing spring 2019 deadman gold. And You also can obtain RS3 gold , RS 2007 gold and other products from https://www.rs3gold.com/rs3-gold on mobile.
Jan 22, 2019 | Sony Computers & Internet
Computers & Internet Logo
27 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
