Question about Microwave Ovens
H98 on my microwave - Microwave Ovens
    Top Expert:
  • Microwave Ovens Master
  • 62,106 Answers
TRY GOOGLE FOR MAKE AND ERROR CODE
Posted on Jan 24, 2019
5 Suggested Answers
SOURCE:
MicrowaveSvc
  • 9156 Answers
SOURCE: MESSAGE DISPLAY H98
The H98 fault on a Panasonic can be a bad magnetron, inverter or control panel.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 29, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: microwave will not work...display reads H98
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Dec 15, 2009
  • 8404 Answers
SOURCE: microwave Panasonic H98
Please check your door safety interlock switches.
When you open the door with the oven running, to check stuff, there is an arc on the tiny contacts. Eventually, they burn and are not able to tell the oven that the door is shut. Forget what you know about the door, the oven has to be sure the door is shut and it uses these little switches for that purpose.
There are other reasons for no heat, this is the most likely one. Check them with a volt/ohm meter. If failed, get replacement from Panasonic, your appliance parts distributor in your town, FixYa.com advertiser, Radio Shack or www.repairclinic.com
Good luck with your repair.
Thanks for your interest in FixYa.com
Posted on Feb 23, 2010
  • 8909 Answers
SOURCE: H98 WILL
Take it to a Panasonic Repairer as there are no user serviceable parts inside.
Posted on Mar 07, 2011
Trouble code H98
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Code H98
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
You can order Panasonic parts & accessories from Encompass here or you can call them toll-free at 866-779-5835.
Nov 30, 2013 | Panasonic Genius Prestige Inverter...
Our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Sep 14, 2012 | Panasonic Genius Prestige Nnsd997s...
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Dec 31, 2010 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Microwave will not work...display reads H98
Dec 14, 2009 | Panasonic Microwave Ovens
I HAVE MIC. NN-SD997S ,IT DOES NOT WORK ,MESSAGE SAYS "H98" .
This displaying indicates a
problem with the microwave
generation system
This is for your dealer to resolve
Mar 11, 2009 | Panasonic NN-SD997S Microwave Oven
Panasonic Microwave
the error code H98 refers to the heating filament on the magnetron, unless you are confident I would not progress further
Feb 18, 2009 | Microwave Ovens
H98 error
Dec 31, 2008 | Panasonic NN-H965 Microwave Oven
MESSAGE DISPLAY H98
Jun 27, 2008 | Microwave Ovens
Microwave Ovens Logo
44 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
